S type not turning over
Old Feb 1, 2023 | 09:05 AM
Newcomer's Avatar
Angry S type not turning over
Hi car was starting & running ok so I decided to add a Bluetooth module & now the car won’t start, when I turn on ignition all lights up ok the needles in the instruments move fully over then return to the normal positions but nothing else works.
has anyone got any ideas what’s happened ?….or what to look at
thanks in advance. Also no central locking etc
Old Feb 1, 2023 | 09:14 AM
S-Type Owner's Avatar
Have you checked the fuses, particularly the circuit to which you added the module?
Old Feb 1, 2023 | 09:42 AM
neilr's Avatar
First check would be to see what voltage the battery is showing. Maybe it's just drained.
Old Feb 1, 2023 | 10:40 AM
Newcomer's Avatar
I should have know better, car has been standing for just over a week just checked battery voltage & yes it had drained to 7.5 v so it’s on charge now & everything is working as it should
thanks to you both for your input
regards
Old Feb 1, 2023 | 11:24 AM
NBCat's Avatar
Charge the battery for five hours at 2 to 5 amps and retest. If there's less than 12.6 volts showing when checked with a voltmeter across the terminals, the battery is suspect.
Old Feb 1, 2023 | 12:24 PM
kr98664's Avatar
Originally Posted by Newcomer
car has been standing for just over a week just checked battery voltage & yes it had drained to 7.5 v...
Good to hear you caught the dead battery and resultant no-crank.
Next you will want to investigate why the battery went dead. That's not normal. I've left my car sitting for several weeks with no issues. Two basic possibilities:
1) You've got an external drain killing the battery when not in use. More details here:
https://www.jaguarforums.com/forum/s...-drain-123535/
2) The battery is on its last legs and can't hold a charge for more than a couple of days. If driven every day, you may never notice, but if it sits for several days it dies.
The problem could be either scenario, or a combination of the two.
davidmaria1
Jun 10, 2022 06:31 PM
Builder1940
Jun 10, 2017 03:57 AM
bert_vdp
Mar 3, 2012 08:44 AM
macksjaguar
Jan 28, 2012 04:52 AM
benscab
Jul 28, 2011 09:15 PM
