x type lights on but nobody's home
Old Jul 28, 2011 | 01:25 PM
benscab's Avatar
Default x type lights on but nobody's home
hi guys, went out to start my x type today, ignition lights come on but then nothing ? tried and tried in vain to start the car but nothing . eventually it did turn over and start once, but then as soon as i turned the ignition off, it wouldn't start again. anyone any ideas what the problem could be ?
please note, im not very technially minded so you may have to explain in depth- sorry! and thanks.
Old Jul 28, 2011 | 02:13 PM
Arrggghhhh!!!! I need a drink.
Please post tech questions in the tech sections of the forum. ie X Type section, the guys will help.
For info see this.
Hope you get things sorted.
Old Jul 28, 2011 | 09:15 PM
Thermo's Avatar
Veteran: Navy
Ben, odds are, you have a bad battery. PUt it on a charger and see if that helps any. Once you get the car started, drive it to an auto parts store and have them test the battery. If you can't get the car started, then you will need to pull the battery out and take it to the auto parts store. I'm placing money on a bad battery and I don't gamble. If they say that the battery is good, then you most likely have a bad battery cable. I can walk you through that, but you will need to know how to use a multimeter.
stanjag
Dec 29, 2024 08:26 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
kesslari
Aug 31, 2015 04:53 AM
Jandreu
Aug 29, 2015 07:31 PM
gene1
Aug 27, 2015 08:56 PM
