S type R Suspension
Old Mar 26, 2009 | 07:49 PM
NvmyJag's Avatar
You should post this question in the S-Type section. It will get a faster response.
Old Mar 27, 2009 | 05:47 AM
JOsworth's Avatar
How fast are you hitting pot holes that you reach full compression on the suspension? You may want to look at the tires you are running as a starting point. I've run various cars with profiles as low as 35's without an issue. I live in the rust belt of Ohio, so I am familiar with potholes. Look for a tire with a higher load rating than the car requires. This will get you a tire that is more able to handle impacts without damage. And it will be a lot cheaper than trying to modify an already good suspension.
Old Oct 22, 2009 | 10:35 PM
blish2u's Avatar
i have custom one off rims and low profile tires. i run my tires with 50psi not the recommended psi for the car keeps the rims from exploding in a pothole
way2far
Aug 31, 2022 09:26 AM
Harry Dredge
Sep 3, 2015 03:04 AM
dcvickers
Sep 2, 2015 06:14 PM
Harry Dredge
Sep 2, 2015 02:26 PM
