S TYPE SUNROOF Panel Cover Sunshade
Old May 9, 2018 | 05:46 PM
jaguarstype2007grey's Avatar
Default S TYPE SUNROOF Panel Cover Sunshade
Sunroof Cover. Sunshade. panel yes part 12. Does anyone try to take it out for re upholstery without taking down the entire liner?
Old May 9, 2018 | 09:13 PM
Datsports's Avatar
Yes I have removed mine out through the top before .
You must pull / unclip the plastic screw covers from each side to expose the four screws that retain the glass frame.
Then remove the glass out the top .
Then remove the wind deflector , and the blind Panal slides foward and up and out through the hole .
Good time to grease the worm drives and rail sliders as well .
Old May 10, 2018 | 08:43 AM
Datsports Thanks! you for the response it is very frustrating driving a car with this kind of issue specialty a Jag, also depreciates the value immensely if you want to sell it.
Look like it is a light at the end of the tunnel ! Your answer give me hope!
Few more questions if I may;
How do you remove the foam/ old glue from the actual panel(plastic).
Do you have any pictures, drawing, etc how to tackle this issue i.e.
remove the glass out the top .1
remove the wind deflector 11
remove blind panel 5
Old May 10, 2018 | 08:58 PM
aholbro1's Avatar
Originally Posted by jaguarstype2007grey
Datsports
A stiff-bristle scrub-brush should dispatch the rotten foam. The dried adhesive is probably ok as-is, but you can probably clean it off with acetone or similar solvent. But beware your solvent is compatible with the panel base material (I have no idea what the underlying base is)
GrtShrk
Jul 7, 2020 10:04 AM
SuperTrav
23
Jul 4, 2012 10:22 AM
jimatvs
Aug 25, 2011 08:38 PM
mrbones
Dec 31, 2008 10:31 PM
