S-type Visors - correct match
Old Apr 28, 2014 | 11:13 AM
Riggs1955's Avatar
Default S-type Visors - correct match
I have a 2003 S-type that I need to replace the visors in. The mirrors overheated and melted the plastic on the first set. I bought a second set and had the same issues - lights staying on even though the visor was in the up position. Found some with little slide levers and thought those would work as they said they fit 2000-2008 or something like that, and then found they did not fit correctly - they were slightly bigger than the ones I took out and rub the headliner when you swing to the side..
Can someone tell me how I can make sure I get correctly fitted visors? Looking for LH and RH Gray visors on eBay...but tired of paying for ones that don't work/don't fit.
If anyone has a source - let me know....
Thanks,
Jeff
Old Apr 29, 2014 | 06:04 AM
Riggs1955's Avatar
Will 2004's fit ? the ones with the little slide lock?
Old Apr 29, 2014 | 02:49 PM
tbird6's Avatar
Sorry I went thru this and purchased them from Jaguar. I had the material getting loose from the intense heat.
They were too expensive and I paid over $200 for each one. However they match and work perfectly.
Sometimes you do get what you pay for.
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Quantico
Oct 13, 2015 10:34 PM
hoodun
Sep 14, 2015 01:26 PM
XJsc-guy
Sep 2, 2015 11:43 AM
