S Type - Window rail/winders
Old Oct 13, 2017 | 03:14 AM
Prads64's Avatar
Default S Type - Window rail/winders
I own a S type 2007 3.0, GCC specs, LHD in UAE. Both front windows and rear right windows have failed Basically they just went down and I got a shop to raise n lock them. I can hear the motor working when I tried to raise. Do you think I will need to replace the whole unit or rails only? and Will the Ford Taurus parts fit the S??
Old Oct 13, 2017 | 03:33 AM
neilr's Avatar
It depends what is broken
Most common is that one of the plastic sliders has aged and cracked. You need to take the door card off and have a look. You can get spares and repair kits on ebay. This type of thing but you need to check whether it looks like yours:
JAGUAR S TYPE WINDOW REGULATOR REPAIR KIT REAR LEFT Top Quality Quick Dispatch | eBay
Old Oct 13, 2017 | 09:04 AM
NBCat's Avatar
Some members of this forum have successfully replaced the window regulator assemblies with those from a Lincoln LS, however one of the door holes would need to be elongated to accept the stud.
Here is an example:
Power Window Regulator For 2002-2008 Jaguar S-Type Front Driver Side | eBay
Old Oct 13, 2017 | 10:38 AM
clubairth1's Avatar
Community Influencer
No the Taurus ones don't fit. You can change the plastic parts as mentioned above but after a number of repairs I now just change the entire regulator minus the motor. The motor almost never goes out.
It's not a big repair just be careful of the interior so you don't damage something visible.
Shredder
Oct 18, 2021 04:53 AM
unpredictable1
Aug 7, 2017 11:17 AM
Jagger62
Aug 3, 2017 08:21 AM
OpenF
Jul 28, 2017 08:08 PM
Joshua Silva
Jul 18, 2017 04:53 PM
