Self-levelling headlight issue
Old Apr 2, 2018 | 06:15 AM
Russell11's Avatar
Default Self-levelling headlight issue
Hi,
The self-levelling headlights on both sides of my 2003 S-Type R stopped working overnight. Can anyone please tell me why this has happened and how it is fixed?
Old Apr 2, 2018 | 07:28 AM
I've moved your question from New Member Area - Intro a MUST to S-Type forum. This is the place to post technical questions about your model.
Old Apr 2, 2018 | 07:52 AM
aholbro1's Avatar
They're likely broken. Do an advanced search on this forum for threads initiated by "Brutal" containing the keywords Headlight fix. On the other hand...maybe you're the lucky one and have only blown a fuse. (I'm interpreting your post to mean the leveling/adjusting mechanism is what has quit, and that the lights still illuminate?)
Old Apr 2, 2018 | 03:18 PM
Joedotcom's Avatar
Hi
There's most probably a issue,
you need to plug in to find what the fault is
When I first bought my car they did not work and mine was the front level sensor
there's also one at the back
also worth remembering if you unplug a headlight with the battery connected, the self leveling stops working and can only be reset with jaguar IDS/SDD
I replaced the front sensor as it was the fault listed and reset it and its been fine for years
cheers
Joe
Old Apr 3, 2018 | 05:19 AM
Russell11's Avatar
Where is the front sensor located?
Old Apr 3, 2018 | 07:33 AM
Datsports's Avatar
On the lower control arm / wishbone.
It may just need reset as stated above.
Or indeed broken .
Are they pointing down ? This would indercate broken . Then there's two options
1, replace the adjusters.
2, the Brutal fix .
or are they just not doing the down up sweep on start up ?.
I can't recall but with head light delay ? or was it auto on activated , stopped my car from doing the sweep . So maybe check both those functions are deactivated .
In which does not render the auto leval inoperative .
Just no sweep
Alan E L
Jul 7, 2013 06:55 PM
wearlej
May 30, 2013 07:07 AM
pdr1966
Nov 22, 2010 03:58 PM
panza
XJ40 ( XJ81 )
May 31, 2009 10:14 AM
kamilb1998
XJ40 ( XJ81 )
May 17, 2009 07:33 PM
