Setting the Timing
Old Mar 21, 2015 | 08:00 PM
seagates5's Avatar
Default Setting the Timing
Is there anyway to set the timing without having to take off the timing cover?
Old Mar 21, 2015 | 08:11 PM
NBCat's Avatar
It is always helpful to advise the Forum on the MY, engine size and type and number of kilometres/miles on the vehicle when asking for assistance.
Old Mar 21, 2015 | 09:17 PM
seagates5's Avatar
I didnt realize that my signature does show when I post from my phone ... Its a 2001 S Type V8 180k Miles
Old Mar 21, 2015 | 09:35 PM
NBCat's Avatar
You must remove the cam covers and rotate the engine in a clockwise direction when viewed from the driver's position to determine if the cams are timed correctly.
The JTIS Workshop Manual has details on the procedure.
Old Mar 22, 2015 | 09:39 AM
NBCat's Avatar
Just to be clear, if you are standing in front of the vehicle, the engine must be rotated in a clockwise direction only. Rotating in an anti-clockwise direction can cause damage to the main crankshaft bearings.
In order to remove the LH (driver's side) cam cover, use a tool designed to disconnect the fuel line 'quick-connect' at the chrome connector. When reassembling the connector, be sure it 'clicks' into place so you have no fuel leaking onto the engine. It can be fiddly, so take your time.
Old Mar 22, 2015 | 09:43 AM
Mikey's Avatar
Was this not covered in the OP's last post?
Sprayall
May 30, 2021 08:13 AM
XJsc-guy
Nov 23, 2015 01:56 PM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
