shifter assembly fix
Old Jan 26, 2014 | 04:02 PM
Robert Carby's Avatar
Default shifter assembly fix
Is there a metal shift linkage that replaces the plastic component that frequently breaks for the 2000 s type 4.0? I have read that there are replacements for the 2004 and above but not the earlier years.
Rob Carby
Old Jan 27, 2014 | 07:35 AM
Welcome to the forum Rob,
I've moved your question from the end of a two year old vendor thread to the S-Type forum. Members here with the same model will be able to help with the latest information.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 27, 2014 | 08:22 AM
It is the early, pre 03, cars that have the problem with the broken plastic part here's a couple of links shift.kit.stype - Shifter Repair Kit Jaguar s Type Shifter Repair Kit All Metal Durable | eBay
Old Jan 27, 2014 | 10:12 AM
JagV8's Avatar
The later ones seem not to break. The earlier ones are prone to breaking quite often due to heaving on the shifter. And that's often due to failing to use the parking brake. (The fix is to use that brake.)
Old Jan 27, 2014 | 12:28 PM
tbird6's Avatar
Just be careful! The reason it breaks is because it's a safety joint.
It breaks before something much more expensive does. So making that piece stronger is fine but don't get rough with the shifter after that because that part won't break next time.
You did not say but many times you can’t move the shifter because the parking pawl gets locked when the car is parked on an incline. Then the weight of the car is locking the parking pawl. Try rocking the car gently back and forth while gently trying to move the shifter.
You can help prevent this by parking on flat surfaces or applying the parking brake BEFORE putting the car in park.
trosty
Jan 8, 2016 06:43 PM
neruda
Oct 18, 2015 01:19 PM
Phil G.
Sep 12, 2015 07:42 AM
1964Daimler
Sep 9, 2015 11:28 AM
avern1
Sep 8, 2015 06:25 PM
