shock absorbers
Old Jan 3, 2018 | 02:35 PM
REG's Avatar
REG
Default shock absorbers
hi took out rear shocks to change bushes, now shocks are 75mm lower then the hole to bolt back up, help please
Old Jan 3, 2018 | 02:39 PM
NBCat's Avatar
Have you tried to push the control arm down to line up the bolt hole?
Old Jan 3, 2018 | 02:46 PM
REG's Avatar
REG
yes but will only go down a little
Old Jan 3, 2018 | 03:12 PM
NBCat's Avatar
Did you disconnect the anti roll bar link? That should give sufficient room to move the suspension down to line up the bolt hole.
If you haven't already done so, download the Workshop Manual and follow the procedure for removing and replacing the rear shock absorber and spring.
Old Jan 3, 2018 | 03:43 PM
REG's Avatar
REG
hi that was my next move, I thought I might get away without doing it, thank you
pinheaduk
Feb 7, 2011 11:08 AM
H20boy
General Tech Help
Oct 31, 2010 08:27 PM
webdesignhelper
Jul 25, 2008 08:35 PM
Apr 26, 2006 01:29 PM
