Single Use Bolts?
Old Feb 23, 2022 | 11:07 AM
Dhankin's Avatar
Default Single Use Bolts?
Hey gang. Are the transmission pan bolts single use? I serviced the transmission in my car with a new pan, but old bolts and it's leaking. I called an independent shop that specializes in Jaguars for an estimate to have them fix it and they're telling me the bolts need to be replaced. It's a reputable shop, I'm sure they're correct, but I'd not heard this. Do you guys servicing your own cars use new bolts with transmission services?
What other services should require new bolts? I have a leaky valve cover gasket I'm going to need to do soon. Are those also single use? Why?
Thanks!
Old Feb 23, 2022 | 02:31 PM
scottjh9's Avatar
Zf recommends new bolts because of possible breakage. If you torqued the bolts in proper sequence then you have another problem. Retorque them and see. Bolt stretch is what the issue might be. The sequence is very important. New bolts will not hurt though if you decide to go that route. Also double check that the seal sleeve is not weeping onto the pan area. I used my original zf bolts and had no issues. After the fill was completed and trans warm i retorqued
Old Feb 23, 2022 | 03:03 PM
kr98664's Avatar
Originally Posted by scottjh9
Zf recommends new bolts because of possible breakage...
Was breakage the issue? Working from potentially faulty memory, I thought there was an update to a new style of bolt head. I vaguely remember the original style was easy to strip out.
Submitted with a grain of salt.
Old Feb 23, 2022 | 04:18 PM
scottjh9's Avatar
you may be right Karl. I think the new style are t40. Maybe old t27 or 30. I have t40
Old Feb 23, 2022 | 04:45 PM
clubairth1's Avatar
Community Influencer
I think ZF said the early small Torx head bolts tended to seize into the Aluminum transmission case. When trying to break them free this corrosion required more torque than the small bolt head could take. So they had a lot of complaints because the bolt heads stripped out. Note if this happens to you remember the pan is plastic and you can break the plastic off around the bolts and use vice grips to unscrew the bolts.
The newer bolts are still steel so same corrosion problem but with the larger Torx head on them they can take more torque without problems. I have been using the new bolts and applying a small amount of anti-size to the threads. I have never had any problems removing the smaller bolt heads but I think it depends on how much salt the car has seen.
Old Feb 23, 2022 | 05:38 PM
scottjh9's Avatar
Excellent
Old Feb 23, 2022 | 07:45 PM
motorcarman's Avatar
WHAT GEARBOX????????????
The S-Type came with the FORD 5R55N (early cars) and the ZF 6HP 26. (later cars)
Discussion without knowing what gearbox is a waste of time.
Old Feb 23, 2022 | 08:13 PM
scottjh9's Avatar
Well according to his profile he has 2003 s type r and a 2004 xj8. Yeah he should have mentioned the vehicle but i think both have zf. Anyway i just gave my best answer sorry
Old Feb 24, 2022 | 07:28 AM
Dhankin's Avatar
Thanks for the replies. It's the ZF6HP26. The first time I did this service (on my XJ) one of the bolts was seized in the case and I had to drill it and helicoil it. If that was an issue, makes sense if they changed bolts to prevent it.
Appreciate all the insight. Thanks!
Old Feb 24, 2022 | 08:05 AM
kr98664's Avatar
You've been on the forum long enough that I shouldn't have to remind you about protocol. There's no need to reply stating the obvious, i.e. me being right. Think of how much bandwidth would get tied up, bringing the entire internet to a screeching halt.
Old Feb 24, 2022 | 08:58 AM
clubairth1's Avatar
Sorry Karl! Yes the 6 speed ZF.
Old Feb 24, 2022 | 09:20 AM
scottjh9's Avatar
well. Being up there in oregon i figure this time of year is a lot of rain and clouds. I just wanted to give you a ray of sun🤙
mott
Aug 21, 2021 09:32 AM
Thood691
20
Nov 18, 2020 09:34 PM
OUScooby
Dec 8, 2018 01:06 PM
JBfountain
Feb 27, 2015 11:41 PM
75Gremlin
General Tech Help
Aug 30, 2014 01:59 AM
