Solved Engine Coolant low but it wasn't the tank or sensor.
Old Mar 15, 2019 | 12:51 PM
David SD's Avatar
Default Solved Engine Coolant low but it wasn't the tank or sensor.
From what I have read, the vast majority of "engine coolant low" messages (despite normal coolant levels) stem from issues with the tank, often a faulty sensor which requires a new tank. I had the same warning light but it was caused by electrical corrosion further up the line, It seems the connector was exposed to water at some point. The mechanic cut off the wires and soldered each wire into a new connector. Problem solved. Total cost including diagnosis was $300 (two hours labor plus 30 for parts).
Old Mar 15, 2019 | 01:27 PM
joycesjag's Avatar
WOW, thank you for update.
Bills
Oct 18, 2024 03:13 PM
May 3, 2023 08:44 AM
srpope80
Jan 6, 2019 03:47 PM
vdpnyc
Oct 3, 2016 02:29 AM
jimlombardi
Mar 27, 2011 05:43 AM
