Speaker wiring?
Old Aug 12, 2008 | 10:19 AM
ccajun4real's Avatar
Default Speaker wiring?
Can I wire this by jumping it off of one of the rear speaker leads?
Bazooka BTA8100 amplified bazooka tube
http://www.crutchfield.com/S-dvC2dqM...x?I=204BTA8100
Thank you in advance.
Cajun
Old Aug 12, 2008 | 11:37 AM
badmojo's Avatar
Default RE: Speaker wiring?
I think if you do that you will only get the channel that goes to that speaker coming thru the tube. I would assume that you want all of the bass to come thru the tube. I would consult a audio installation shop or see if you can find the wiring diagram somewhere online. You really want it to work right or you'll be really dissapointed. Even if you have to pay a little to have it installed it would be worth it.
Old Aug 12, 2008 | 12:14 PM
I just realized that I now have an aftermarket head unit in the S so will probably be able to hook up directly to the sub output. I dont know why I was thinking I had to use high level inputs on this thing. Thanks for the advice.
Cajun
Old Aug 12, 2008 | 12:24 PM
03 S Type's Avatar
Cajun,
I'd wire directly to sub output. I just did my setup a few days ago with a 800 watt amp and a 10 inch sub setup. Turned out quite nicely. I think I'm gonna need some dynamat though!
Old Aug 12, 2008 | 12:26 PM
ORIGINAL: 03 S Type
Cajun,
Do you get alot of vibration? Does the sub pressure cause the rear deck speakers to distort and move? Thanks
Cajun
Old Aug 12, 2008 | 03:40 PM
ohsigmachi's Avatar
I'm pretty sure you could wire that (use the speaker wires that come out of the factory amp to the package tray "subs") into the speaker level inputs and be just fine. I'm honestly not a fan of the Bazooka's, but I doubt you will notice any real difference between the two wiring setups. If you were using a very high end sub with a very powerful amp then I would say you want the purest signal you could feed it, I doubt the tube will notice and neither will your ears.
2001 White XJ8
Feb 25, 2021 05:02 PM
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
R-Sport
Sep 18, 2015 01:44 PM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
