Spring orientation?
Old May 2, 2013 | 09:44 PM
ncjagguy's Avatar
Default Spring orientation?
While replacing my suspension bushings and other pieces, I forgot to mark the rear spring orientation. Could someone let me know how the springs are supposed clocked?
At the moment the driver side front spring coil end faces in towards the body, the passenger front spring coil end faces in towards the body, the driver rear spring coil end faces in towards the body. However the passenger rear spring coil end faces the outside or away from the body.
Wow it must have been really late and I was really tired, so many spelling errors. So no one have any comments? To be more specific I did not change the shocks and springs so I have not dissassemble the shock / spring assembly. Thererfore the spring end as described in JTIS is stil in the same orientation in the spring cup. However the shock assembly can be installed in two orientations which are 180 degress opposite each other in the vehicle, does this matter?
Any help or pics would help
Thankd
SD96XJ6L
Dec 27, 2025 09:58 PM
tlynch
Dec 31, 2020 01:58 PM
multistrada74
Oct 8, 2015 08:58 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
