STR Transmission
Old Mar 18, 2011 | 11:56 AM
JagV8's Avatar
Is the proper dealer tool (IDS for Jaguar) being used to reflash the TCM?
Anyone recall another TCM not reflashing OK (if Jaguar IDS was used and used properly)?
Old Mar 18, 2011 | 12:10 PM
kmrod22's Avatar
It was attempted at both his shop and Rusnak. Same result. They said that they have seen the computer fail previously. It has something to do with the pulling all the info off and then reloading. But right now it seems that I'm kind of f'd because it won't take the new software.
Old Mar 18, 2011 | 03:16 PM
kmrod22's Avatar
We ended up finding a trans out of an xjr that seemed to meet all the specs for a great price. The guys is being more than fair on his install. I would still like to know if anyone else has had a computer failure like this one?
Old Mar 18, 2011 | 08:46 PM
joycesjag's Avatar
First I've heard of it in over 2 years.
Are they able to load the old software back in out curiosity? Did they try?
Are you also going to be replacing your TC with the XJRs?
Old Mar 18, 2011 | 09:11 PM
kmrod22's Avatar
Not sure if they tried loading the old software. From the explanation that I got I doubt it would work as the whole thing seemed frozen. And yes my understanding is that they are swapping the tc as well. Actually I think I would have been a little more upset about this if I didn't believe the old tc was going to have to be replaced anyway. From what I've seen those are going for around $600 so by the time I finished paying for labor and everything else I would have been looking at close to $1000 anyway and would still have an older trans. As it is I should be out the door for not a whole lot more. If I was driving an old Ford I'd be po'd but given what the car is I can't complain too much.
Old Mar 18, 2011 | 09:13 PM
joycesjag's Avatar
Man I feel for you, this really sucks but atleast you are getting somewhat of a deal. I hope it works out for you! Keep us posted.
Old Mar 19, 2011 | 11:30 AM
kmrod22's Avatar
Will do should be ready monday.
Old Mar 21, 2011 | 11:03 PM
  #28
kmrod22's Avatar
Got the car back and all seems to be working well. He also added the power steering additive which seems to have eliminated the squeeky steering. The next task is changing the headlights. Just a heads up on the early cars with this transmission the computers are fragile. He had another one the same year have a similar failure right behind mine. The initial failure occurred at the dealer this time. The upside in a way is that after pulling the transmission it appears that it probably didn't have much life left in it anyways. I can't recall right now but I have an e-mail out to find out the exact year and model of the donor car. I do know that it was newer with an updated computer. Also of note it seems to have eliminated that slow to close to stop and then go lurch that I used to experience and have read others have as well. Finally the key fobs now work which they didn't prior to this. This is the second time that I have had other problems with the car that the key fobs have gone dead. The first time it was a worn ebrake pad which threw 30+ codes. Bottom line I really do like this car but I think you would have to in order to deal with some of the issues.
Old Mar 22, 2011 | 10:20 AM
kmrod22's Avatar
The trans came out of a late run '04 XJR. Evidently there were some upgrades from the 03's
Old Apr 14, 2011 | 06:41 PM
  #30
cyberpanther's Avatar
Oh no my car is exhibiting the exact same problems RPMs fluctuations which are worse when it is cold outside, followed by car just now getting to stuck in 3rd gear.
Any idea how much this would cost at a Jaguar dealer?
Old May 2, 2011 | 10:29 AM
  #31
kmrod22's Avatar
Here's my take on it. First I would try to find a legit Jag Mechanic with the computer to do the flash. The dealer will hit you for at least $300. The downside is that there is no guarantee that it will solve the problem. You could have a bad Torque converter or the whole trans could be going bad. In my case I think the problem was more than just the flash so it's probably just as well that it worked out as it did. But if you can find a guy with the computer they will probably charge you around $100 for the flash and that's certainly worth taking a shot. Also as an add'l benefit my new trans doesn't experience that lurch that I used to get when I slowed to an almost stop and then start again. Anyway best of luck cyberpanther.
Old May 2, 2011 | 10:59 AM
  #32
JagV8's Avatar
The reflash should (and almost always does) cure "the lurch".
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
JTC3400
Sep 29, 2015 05:03 PM
Old_Doc
Sep 29, 2015 03:43 PM
SoCalJagS
Sep 27, 2015 09:20 AM
