Strange Key Fob Issues....
Old Jul 6, 2013 | 12:40 AM
QuartzSTypeR's Avatar
I had a strange key fob experience today. I drove my car, parked it and locked it with the fob, no problem. I come out, unlock it just fine, drive for about 30 minutes, park it and it the fob wouldn't lock the car. None of the buttons did anything at all. I figured the battery had gone bad, so I replaced it (all the connections looked fine when I had it apart), and still nothing on the fob worked at all. I go about the rest of my day, get home and grab my other fob. All the buttons on it work normally. As soon as got done testing it, I grab the one that wasn't working and all the buttons were functioning again normally. Any ideas?
Old Jul 6, 2013 | 08:34 AM
WhiteXKR's Avatar
Originally Posted by Jon89
Update:
Steve (WhiteXKR) is truly a wizard. He resoldered the loose chip back onto the key fob board, found some other suspect solder points on the board that I had not noticed before I mailed it to him, and resoldered those weak points as well. It is amazing how perfect his solder points are. They put the factory solder points to shame....
Not only does my S-Type key fob work perfectly each and every time now, but its operating range has increased at least three-fold....
Many thanks to Steve for his considerable prowess with these circuit boards. He has inspired me to take much better care of my key fobs going forward....
Jon, I am really glad it worked!
It appeared that the original soldering on your fob was not very good from the factory, and the connections began to fracture from years of use.
No wizardry involved, just many years of experience designing electronics.
Old Jul 6, 2013 | 09:33 AM
Jon89's Avatar
QuartzSTypeR,
Your symptoms sound very similar to mine during the past year or so. Every now and then my S-Type fob would refuse to work. I would take it apart and clean the circuit board, battery contacts, and rubber pad with alcohol and Q-Tips. That would usually restore the functions for awhile. Then I discovered that if I used my wife's rarely-touched S-Type fob while holding my own fob next to it, my fob would magically began working again for awhile. At the end of last week when I took my fob apart for at least the 5th or 6th time in order to clean the innards, that's when the chip fell off the board and onto my kitchen table....
Try taking your fob apart and cleaning all components of it. That may buy you some time. But if these devices are not particularly well-crafted at the factory as Steve has apparently discovered, a refurbishment similar to mine may be your eventual solution....
Old Jul 6, 2013 | 09:37 AM
That's quite possible, I replaced both mine recently and the function was vastly superior to what the old ones had deteriorated to.
Maybe a new career on the horizon for Steve?
LnrB
Oct 13, 2015 12:45 AM
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
