Supercharger life?
Old Mar 16, 2008 | 08:47 PM
embassured's Avatar
Default Supercharger life?
How do you know when the supercharger is nearing the end of it's life? Do you get code or restricted performance light?
Has anyone had one go bad yet?
I'm not having any problems - just trying to figure out if the S/C is the "life of the engine" or do they typically need rebuild at some usual mileage figure.
Thanks,
Eric
Old Mar 17, 2008 | 04:40 AM
FactoryJaguarTech's Avatar
Default RE: Supercharger life?
Only replaced one for cracked vain. Other than that have swapped them from motor to motor and they still good. 100k +
Old Mar 17, 2008 | 11:24 AM
badmojo's Avatar
Mine was making noises like there were marbles bouncing around inside. It was replaced under SE. Dealer said it was very rare.
Old Mar 17, 2008 | 05:58 PM
jag_genius's Avatar
i ve done a couple for noisy bearings.. chargers do need there oil changed.. on xj 98-2003 there was a fluid change interval and fluid in a tiny bottle.. cant remember for s type .. probably the same.. and it has a drain plug at the back of the charger.
Old Mar 17, 2008 | 07:28 PM
embassured's Avatar
Ooooh, that was a new tidbit of info; i.e. oil change.
I don't recall seeing an interval change listed in service/maintenance guide.
What interval do you recommend and what type of oil?
Many thanks!
Eric
mikiep
Dec 20, 2019 07:37 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Col. Sandurz
Sep 28, 2015 07:29 PM
