Tail-light/Break light failure
Old Mar 29, 2008 | 01:51 PM
jag_genius's Avatar
Default RE: Tail-light/Break light failure
are you actually seeing the light come on? when the brakes are pressed?
Old May 1, 2008 | 09:00 PM
H20boy's Avatar
Did you replace the bulbs with 3rd party (1156/1157 styles) or P21Y?
Old May 2, 2008 | 12:13 AM
H20boy's Avatar
Jaguar uses the P21Ws in their brake and tail lamps. If you use the 1157s, they will work, but will display an error message. Different resistance in the bulbs; computer still thinks they are burned out. I haven't seen them in Autopart stores, but you can always try around your area. I buy mine online when needed (until going LED that is)
Old Jun 24, 2008 | 11:50 PM
ausman46's Avatar
Had the same problem, but my tame auto elec solved it.
Non std bulbs have slightly different fitting lugs on the side - genuine ones have one hi and one lo and slightly offset.
Fit them and the message goes away.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
vsol
Aug 29, 2018 09:46 PM
mrplow58
Sep 9, 2015 11:27 AM
avern1
Sep 8, 2015 06:25 PM
