Tie rod installation
Old Mar 14, 2019 | 11:06 PM
rtdbuild's Avatar
Default Tie rod installation
I ordered a complete set of front suspension parts for my 2001 so type 4.0. After a text book install, (which I thought) I'm getting a rubbing sound on my rim. Is there a difference in left and right front tie rods. I haven't moved the car besides pulling in garage and back in.
Old Mar 14, 2019 | 11:25 PM
Vee's Avatar
Vee
Make sure it's not the caliper cover. Sometimes I bend those when I'm working around them. It's that thin metal cover on the inner side of the rotors.
rtdbuild's Avatar
Default Front suspension rebuild
Installation of new front suspension parts for my 2001 s type 4.0. After a text book install (which I thought). Is there a difference in left or right sides of outer tie rods. I couldn't replace right side due to a frozen tie rod which would not come off, so I'm waiting on inner tie rods so I can complete job. So here's my issue: front left outer tie rod rubbing on rim. Did I put the wrong tie rod on the wrong side. Oops! It's only on on outer turn (wheel out)
Last edited by rtdbuild; Mar 14, 2019 at 11:40 PM. Reason: Forgot vital information
Old Mar 14, 2019 | 11:30 PM
rtdbuild's Avatar
That was first thing I checked. I put car up on stands in front and turned wheel and can see the rod rubbing on inside of rim.
Old Mar 15, 2019 | 06:38 AM
joycesjag's Avatar
1) compare new tie rod to old
2) compare new tie rod to new tie rod
3) are the part numbers the same for both sides?
4) call parts supplier have them check
Old Mar 15, 2019 | 03:32 PM
rtdbuild's Avatar
Default Reply
True! One I side I have that I did not change matches perfectly to the old one I took out..so perhaps there is difference. Apples to apples ? Thank you again!!
Old Mar 15, 2019 | 08:41 PM
rtdbuild's Avatar
Default Note
Check, check, check..your parts to make sure right is right and left is left. Thank you for pushing my lazy butt to check that out.
Old Mar 18, 2019 | 09:32 AM
neilr's Avatar
Just to be clear, the tie rod ends are handed but the track rods themselves are identical, right?
Old Mar 18, 2019 | 09:47 AM
rtdbuild's Avatar
I put the tie rod end in reverse. So..drivers side is complete, right side has a frozen outer on the inner.not sure what a track rod is. Inner tie rod?
Old Mar 18, 2019 | 11:09 AM
neilr's Avatar
Got you now. The tie rod or track rod is the straight bit from the rack? The track rod end is the outer part with the ball joint, which is often but not always handed.
Old Mar 18, 2019 | 11:24 AM
rtdbuild's Avatar
Exactly!!
SamOscarBrown
Nov 4, 2013 08:16 PM
daboss085
Nov 1, 2012 05:13 PM
Baby_Jag
May 4, 2010 11:30 PM
GordoCatCar
May 8, 2008 12:47 PM
xb70valkyrie
Nov 23, 2007 11:57 PM
