Tinted My Side Markers
Old Feb 9, 2012 | 09:31 PM
rasputin's Avatar
Default Tinted My Side Markers
A few weeks ago I decided it was time to finally tint my side markers. I followed the guide which is linked below:
HOW TO: VHT Headlights and Tail lights - MustangForums.com
To remove your side markers, simply press down, relatively hard and then wiggle them out. Remove the bulb enclosure by twisting it off. Its straight forward and takes 2 minutes.
The guide is about 90% awesome, but I have a few pieces of advice. First, build yourself a mini painting booth like I did below. Take a show box, or two, and cut them wide open. Insert two coat hangers through the box about 4 inches apart so you can lay the side markers easily on top. This allows your spray can to reach the edges as well as provide full maneuverability when spraying. I did it on top of my trash cans since I dont care about my trash cans and its at a good height.
I did about 6*2 light coats, meaning I sprayed one side really fast and then sprayed the other side fast again, doing it for a total of 6 times. I'd almost do it 7 times if I could do it over again as some color shows through on a few markers.
Be sure to get the edges!!! Thats why the show box paint booth is imperative.
Once you get to the end during the wet sand, I found that wet sanding for around 1.5-2 minutes is all you need to remove the air bubbles. After that, wax for about 1.5 to 2 minutes by hand and it should come out almost perfect. I made the mistake of using a buffer on the first one and almost ripped the VHT coat right off.
Here are the final results below. Keep in mind I did this because the jag light set up is quite unique. Most cars have wrap around tail and headlamps but the jags are completely flat front and back, forcing the US spec to add ridiculous side markers. Especially on a black car these needed to be tinted out to match the whole car. At night or dusk, the internal bulbs shine through with no issue. Theres no safety issue at all with doing this mod. If you are worried about getting hit because your side markers arent reflecting during the day, you should ride the bus .
My final recommendation is to set aside 2 days to do this. With your whole first day spraying, and your last day( hour) buffing. Definitely start on Saturday and end on Sunday. Enjoy! And you'll notice that this is the way the car should have come stock, very stealth and following the lines/color of the car.
Old Feb 9, 2012 | 09:33 PM
Belac0711's Avatar
That looks great! And I must say, a great looking car all around! Nice work
Old Feb 10, 2012 | 12:09 AM
joycesjag's Avatar
+1, I am with Belac, nice job and the vehicle looks fantastic!
Thank you for sharing and taking the time to post the how to with pics!
Old Feb 10, 2012 | 09:09 AM
Bacardi 151's Avatar
Looks great, never seen this on a black s-type...
Old Feb 10, 2012 | 09:40 AM
Good job!
Take care of the Tempe trash can police!
Old Feb 10, 2012 | 12:08 PM
The Chris X's Avatar
Looks great. I did mine last fall on my Midnite Metallic STR. I used a cardboard box and punched holes in the top so the side marker bulb holders acted like a stand. This allowed me to get all around the lens. I kept is somewhat light, 3 coats. Wet sanded with 1000 grit between coats and then 2 coats of clear on top. No problems seeing them lit at night and they still have a little tiny bit of amber tinge to them in the direct sunlight during the day.
Took me about 4 hours with drying time, total.
Cheap, easy DIY and great bang for the buck.
Old Feb 10, 2012 | 04:51 PM
qikcat's Avatar
I did my markers myself but left the rear tails to the pros. I found that using rubbing compound and wax works just as well as wet sanding without all the trouble. Looks good!
Old Jun 7, 2012 | 10:28 AM
JazzPurr's Avatar
Looks GREAT! I'm going to do this to my '07 Black XJ8!!
Old Jun 7, 2012 | 08:52 PM
jag79's Avatar
Wink
Very very Nice!
Old Jun 7, 2012 | 08:57 PM
rasputin's Avatar
Thanks gentleman, i think we can all agree that our markers should have come this way stock. Please share your results on this thread, thanks.
Old Jun 8, 2012 | 04:07 PM
rocam81's Avatar
Default jag logo on calipers
Are they a cover or the full caliper to get the green logo on the brakes?
Looks great.
Old Jun 8, 2012 | 06:03 PM
rasputin's Avatar
Looks great.
I believe they are stickers and it came that way stock? I think there are some threads on painting calipers and sticker related discussion.
H20boy
Dec 24, 2024 03:23 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
1964Daimler
Sep 9, 2015 11:28 AM
handcuffsready
Sep 7, 2015 03:16 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
