TRANS PROBLEM
Old Apr 1, 2007 | 09:22 PM
Envy337's Avatar
Default RE: TRANS PROBLEM
Keep complaining about the trans.
The whinning is either a bad differential or the driver shaft is out of balance.
Old Apr 1, 2007 | 09:40 PM
badmojo's Avatar
You can disconnect the negative battery cable for about 5 minutes and then reconnect. This will reset the or reflash the trans. It might not change anything but it should'nt hurt it either. Sometimes it will get rid of the lurch or at least make it a little better. If it does'nt work it sounds like you have to bring it back to the dealer anyway so it might be worth a try.
Old Apr 2, 2007 | 10:57 PM
Envy337's Avatar
ORIGINAL: badmojo
Disconnecting the battery for any period of time will NOT reset the transmission control module. You need to reprogram it (at the dealer).
Old Apr 3, 2007 | 02:20 PM
badmojo's Avatar
Sorry, That info was given to me by a member of this forum. Jagmaster said that you could reset the tcu by disconnecting the battery for 5 minutes. Bad info I guess.
Jandreu
Jun 30, 2022 03:10 PM
vsol
Aug 29, 2018 09:46 PM
jdzubas
Oct 4, 2015 09:14 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
Numwen
Sep 6, 2015 12:30 AM
