Transmissions?
What is the difference between the S-type R tranny and v6 S-type and does anyone know the max load that can be transfered through the valve body and tranny?
Yeah I know they weren't very good. I think I'll be safe with the ZF for turbo I want to add. I can't find any compnay that would upgrade the Tranny for more torture but I know I will. I spoke with Swift Reacing and the tranny expert was not in they will see what they can do. They work alot on the IS300's. I am looking for someone that works more with BMW's and I also see the the new Hyundai Genesis comes with ZF so I will keep my eyes open.
Actually I found this at Level Ten
The Real Deal
ALL Parts and Kits Are GUARANTEED TO FIT!
Detailed info on checkout and a
call from our techs make sure of it!
Click Here For Form
Image May Differ From Actual Product PTS Torque Converter Service
SERVICE HIGH PERFORMANCE TURBO SUPERCHARGED
The Best Of The Best!
PTS Torque Converter Svc
Bulletproof Lockup Clutch
Bulletproof Internal Parts
Designed for Performance and Drivability
Modify And Enhance Your Existing Converter For More Power!
Your converter is sent in and performance modified using Level Ten's propriety PTS performance system!
Feel The Power!
This Torque Converter is to be Used In Conjunction With PTS Hydro System For Optimum Performance And Lasting Durability
G310R-9000S3 $1479.00
Image May Differ From Actual Product PTS Bullet Proof Transmission
Get Your Shift Together!
PTS Performance Master Kit
PTS Hydro System Valve Body
PTS Super Oil P ump
PTS Lockup Valve and Super Solenoid
PTS Transmission With Help Eliminate Trouble Codes
PTS Designed for your application
G1800-9000S3 $3998.00
Do It Yourself Bulletproofing Your Transmission
Image May Differ From Actual Product PTS KIT
“GET THE RIGHT COMBINATION” WITH THE STRONGEST CLUTCHES PERIOD!
PTS Seal, Gaskets, Washers, Bushings, And Rings
Detailed Performance Instruction Sheet Included
Includes Necessary Parts To Modify Pump, Valve Body, And Internal Factory Deficiencies
Level 10 Billet Torque Converter is to be used in conjunction with this kit for Maximum Performance
G110-9000 $1223.00
Image May Differ From Actual Product PTS Hydro System
PTS Hydro System
Smooth Firm Shifts
Cures Delayed Reverse
Improved Performance and Longer Transmission Life
G210S-9000 $981.00
Image May Differ From Actual Product PTS Super Pump
PUMP IT UP !
PTS High Volume Pump For A cooler Transmission Temperature
PTS Lockup Valve Technology
PTS Increased Pressure
Level 10 Billet Torque Converter Must Be In Conjunction With this pump
G1400-5620 $786.00
Image May Differ From Actual Product PTS Technical Manual
Easy to use Detailed Factory Rebuild Instructions
Specs & Tolerances
Illustrations
A Must For DIY Projects
B410-1000 $129.00
The Real Deal
Click Here For Form
Feel The Power!
PTS Super Oil P ump
G110-9000 $1223.00
PTS Hydro System
Smooth Firm Shifts
G210S-9000 $981.00
PUMP IT UP !
G1400-5620 $786.00
Specs & Tolerances
Illustrations
B410-1000 $129.00
Marka
22
Sep 11, 2016 12:09 AM
dmatthewman
Sep 30, 2015 10:10 AM
