Turn signal problems
Old Jul 23, 2011 | 03:04 PM
brianp91773's Avatar
Default Turn signal problems
I have an 01 stype my right rear blinker was coming on very dim. I changed the bulb and now when I hit the turn signal the right and left reverse lights blink, as well as the right blinker. all lights are very dim. The left one works fine. there was no message that the light doesnt work on the message display. anyone have any idea what to do? I really dont want to take it back to mechanic as I just put in new tranny and starter costing me almost 6k. Please help.
Old Jul 23, 2011 | 03:25 PM
Jon89's Avatar
Did you use the proper replacement bulb?
Sometimes it's just a matter of the new bulb not being properly seated in its socket, or knocking the other bulbs loose in their sockets while you're replacing the failed bulb or re-installing the taillight assembly back into place....
I would remove the offending taillight assembly again, carefully remove and re-seat all bulbs in it, and then check it for proper operation. If it's working properly again, then carefully re-install the taillight assembly in place and then check it for proper operation one more time....
Old Jul 23, 2011 | 03:48 PM
While you are doing that check the grounds as well.
Old Jul 23, 2011 | 04:52 PM
I havent checked the ground wires, where would these be? I think I used the right bulbs, I got them from autozone and went with the bulbs that the book suggested. I will go out and double check the bulbs now.
JarodL
Mar 7, 2024 01:39 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
