Upper control arms
Old Apr 14, 2026 | 02:44 AM
vmaxie's Avatar
Default Upper control arms
Need to replace the upper control arms on my 2006 S Type R.
There is a lot of choices out there. Any recommendations on which to buy?
Thxs!
Old Apr 14, 2026 | 05:57 AM
Sportston's Avatar
Go for big brand named ones. They use better quality rubber.
Old Apr 14, 2026 | 07:42 AM
Peter_of_Australia's Avatar
Do you?
I am serious: Why do you think that you need to replace them?
I assume you are talking about the front upper control arms (I do not think there are some in the rear).
If it's the grommets: I got myself a whole bunch of generic grommets from China and swapped them all.
If it's the joint of that flexible bolt, which seems to be too lose - has too much play: I gave that joint from it's backside a few targeted hits with a hammer, greased it, and it was as new...
Old Apr 14, 2026 | 11:42 AM
kr98664's Avatar
Here's my experience on my '02:
https://www.jaguarforums.com/forum/s...l-arms-264748/
No idea how similar your '06 would be. Even with different part numbers, I think some of the general procedure should be the same.
Old Apr 17, 2026 | 04:38 PM
scottjh9's Avatar
I have used moog parts for my 06 str and very happy with them. Purchased from rockauto
Old Apr 18, 2026 | 11:06 AM
autoxforfun's Avatar
After 20 years, the bushings on our '06 S-Type R needed some attention....as did the ball joints, tie-rod ends and other rubber parts. I started ordering parts (mostly from Rock Auto) to go through everything in the front and rear of the car. I ordered Moog when available but found Delphi and Dorman to be good alternatives. I also replaced the half-shafts since the CV joints were looking a bit suspect. Once I gathered the parts, I put the car (my wife loves this car) up on stands and did all four corners. Took about a week to complete. What I found was how much better the car drove after (I had the alignment done). You don't notice how it degrades over time until you put it back to how it should be.
wombat
Apr 30, 2026 02:13 PM
jrb53
Oct 25, 2025 07:54 AM
07xjr
22
May 4, 2024 05:47 AM
TimCumming
May 13, 2022 02:43 PM
SD96XJ6L
Oct 6, 2015 07:54 AM
