Upper Radiator Hose plastic piece
Old Nov 18, 2018 | 11:27 AM
jagstype2004's Avatar
Default Upper Radiator Hose plastic piece HELP
? - The plastic piece on my upper radiator hose broke off connect the coolant tank overflow - any suggestions without have to buy a whole new hose? Don't have the $ right now
Old Nov 18, 2018 | 03:23 PM
kr98664's Avatar
Uber?
Lyft?
Transit pass?
Good walking shoes?
Those are my only thoughts short of replacing the entire hose assembly.
Old Nov 18, 2018 | 04:34 PM
Thanks so much for the kind words - I was thinking more on how to repair plastic nozzle to the base
Old Nov 18, 2018 | 05:09 PM
kr98664's Avatar
i highly doubt any kind of repair will hold up.
A threaded fitting into a plastic housing isn’t a good repair. That type has tapered threads that seal by wedging into the hole. Works great into a metal housing. In plastic, this outward force will eventually crack the housing. The only question is when it fails, not if.
I wouldn’t trust any kind of epoxy (or other adhesive) repair, either. Even if you drilled out the housing and inserted a piece of tubing, the adhesive bond is still subject to pressure, heat cycling, and chemical attack. Plus, the housing is now thinner where it was drilled out. Not a recipe for longevity.
Such a critical component isn’t the place to take a shortcut. You don’t want to see a coolant cloud on a long bridge or other place where you can’t safely pull over. In my highly overrated opinion, do it right or wait until you can. Don’t skimp on something that can easily turn your engine into an expensive paperweight. The risk/reward ratio doesn’t work in your favor.
Old Nov 18, 2018 | 11:25 PM
scottjh9's Avatar
Could you post a photo...looking at it will help me brainstorm better
Old Nov 19, 2018 | 12:09 AM
RobGardnerBlack's Avatar
Originally Posted by kr98664
i highly doubt any kind of repair will hold up. The risk/reward ratio doesn’t work in your favor.
I could not agree more; there is nothing that you can do here for a lasting repair. The plastic has a finite life-span and replacement is the only viable long term solution.
slmskrs
Dec 2, 2013 04:11 AM
Backyard Mechanic
Oct 8, 2012 12:42 PM
mursallus
Oct 4, 2011 01:38 PM
Curmudgeon
Jan 19, 2011 11:17 PM
teflondon
Jun 3, 2010 08:11 AM
