V8: No heat from Climate Control
Old Feb 7, 2009 | 10:59 PM
Sogirlish's Avatar
Hmm..I have no idea considering that I just recently purchased one myself. I purchased it from a private owner...she told me the only issue was the heat not working. I put some engine coolant in there and walaah..problem was solved.
Maybe you should fill it up to the max and see if that works first.
Old Feb 8, 2009 | 09:40 AM
Brutal's Avatar
its not software, the rubber valves are stuck in the closed position in the heater control valve. Happens alot esp. here in Txas were it stays shut most of the year and then when you want ot use it its stuck closed, and yes ive taken them apart and youre not going to fix it and reuse the old 1. 2 half the time the stock heater valve damages the drivers in the ac control module(faceplate with buttons, unless you have nav.) so after the control valve is replaced it still wont open or only 1 side does, so you have to replace the ac module. I estmimate both upfront and if not needed no harm no foul, if needed theyre already expecting to replace the module too
Old Feb 8, 2009 | 06:33 PM
bmw745ion19s's Avatar
Since you are using C readings and use the word forecourt i take it you live in England. Im not sure what recourse you have but here in the US most dealer bought cars come with a 30 day, 1,000 mile warranty. I would definitely ask them to pay for the repairs. It probably wont be that cheap to fix
H20boy
Dec 24, 2024 03:23 PM
Steviedee1st
Nov 28, 2023 06:32 PM
Chris Hinton
Sep 24, 2015 08:38 PM
texaspete
Sep 10, 2015 08:34 AM
tberg
Sep 7, 2015 07:32 AM
