V8 woes
Old Aug 16, 2017 | 05:26 AM
dazav8's Avatar
Default V8 woes
Hello, This is my first time posting here i really hope you can help, I have a S Type V8 4.0 Petrol and its not going so well, Car runs really good from cold but when its warm i lose power around 40-50 mph and then i get the amber flashing light, All plugs have been changed, I have checked the coils and replaced the fuel filter, I have had a scanner on it and it shows 0 codes, Not sure if this helps but i have noticed a burning rubber smell too, Smells like its coming from the back but i could be wrong, Hope someone can help.
Old Aug 17, 2017 | 05:00 AM
stevep10's Avatar
Sounds like it's in limp home mode.
What code reader are you using?
Anything that puts the engine check light on should give a code.
You can get a good ELM reader and software for very little money that will give you all the codes needed for proper diagnostics.
Old Aug 17, 2017 | 06:28 AM
JagV8's Avatar
Flashing MIL = severe misfires, doing catalyst damage.
Do not drive it unless you fancy changing cat(s)!!
Figure out the misfire cause urgently and fix it.
Old Aug 17, 2017 | 08:19 AM
dazav8's Avatar
I would love to put loads of money into the car but its already cost me double what i paid for it, The flashing lights do stop when i reduce speed and do not stay illuminated (I dont drive it anymore), I just have no idea what it is, Sparks are new, Fuel filter is new, Checked coils they seem ok, Im at a loss
Old Aug 17, 2017 | 08:21 AM
Mikey's Avatar
You need a better/different code reader.
Old Aug 17, 2017 | 08:37 AM
JagV8's Avatar
And then check for codes then fuel trims.
It's likely to be coils and/or an air leak.
Being a 4.0 you may have a FAR bigger problem - it will need updated (timing) chain tensioners and related parts or sooner or later will trash the engine.
