Warning Noise After Setting ParkBrake
Old Dec 8, 2013 | 10:44 AM
captbob73's Avatar
Default Warning Noise After Setting ParkBrake
Vehicle: 2007 S-Type 4.2 with 21,945 miles
After turning off the ignition and setting the ParkBrake, a warning sounds (Bip, bip, bip...) lasting about 10 seconds.
This warning occurs regardless if the key is in the ignition or not; if the door is open or not; or even if the red ParkBrake is 'on' on the dash.
Cannot find this issued addressed in the owner's manual.
Has anyone encountered this issue? Any recommended fixes?
Old Dec 8, 2013 | 10:54 AM
JagV8's Avatar
Might be thinks trans is not in P.
Most likely if so is that the 2 bolts on trans side for the shifter cable are loose/missing. Check them anyway as they are prone to coming loose and you'll be stranded if so.
Or could be misaligned microswitch for the shift lever itself.
(Or maybe one of the footbrake switches?)
Old Dec 8, 2013 | 11:29 AM
Mikey's Avatar
+1. The shift lever needs to be firmly in the P position.
Originally Posted by captbob73
V
The EPB sets itself. How/why are you setting it manually?
Old Dec 8, 2013 | 12:14 PM
David_h's Avatar
Are you able to manually set the parking brake after turning off the ignition? I would think that the transmission selector has to be in Park to turn off the ignition and therefore the EPB would automatically engage. I do understand that you can manually engage or disengage the parking brake with the engine off with the foot on the brake pedal? Some folks on this forum advocate manually setting the parking brake before selecting Park when on a hill to avoid stressing the shift linkage ( an apparent weak point on many Jaguars including my 1972 XJ6).
Old Dec 8, 2013 | 12:45 PM
salmanezkhanz's Avatar
I had a similar thing happen to me last year, and it ended up being the transmission bolts that JagV8 just mentioned. It's good to have them re tightened every oil change.
Old Dec 8, 2013 | 02:49 PM
JagV8's Avatar
Manually setting - is for the 1999-2002.5MY cars i.e. with non-electric park brake.
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
johndahlheimer
Sep 16, 2015 05:44 PM
mrplow58
Sep 9, 2015 11:27 AM
fingers
Sep 8, 2015 03:54 PM
