Weird fuel info
Old Aug 23, 2024 | 12:40 PM
Grutella's Avatar
Ahh yes I've seen these clamps. Just never used them.
The thing is also that, I had to add some thread seal tape on the plastic parts before putting the PVC hose because they differed in diameter on each side of the round filter you can see on the picture. But I will definitely try those hose constant hose clamps!
Old Aug 24, 2024 | 09:10 AM
kr98664's Avatar
Originally Posted by Grutella
I had to add some thread seal tape on the plastic parts before putting the PVC hose because they differed in diameter on each side of the round filter you can see on the picture...
The different sized barb fittings are going to be a problem. If you select a hose that fits the larger barb, the other end is too loose. Adding sealer tape or cranking down the clamp still isn't going to make a proper seal. If you select a hose that fits the smaller barb, the other end will be probably be too tight to assemble.
Old Aug 28, 2024 | 03:40 PM
Grutella's Avatar
Et voila! I bought slightly smaller PVC hoses and melted the ends with a soldering iron, so they would slide in. Which they did very tightly so, and were almost impossible to pull away. But just to be sure, I added some constant tension clamps. Hopefully this PVC hose won't be eaten away by the gasoline.
Smokey59
Jun 13, 2023 07:15 AM
DanTindell
Oct 18, 2020 06:35 AM
Backhertz
Sep 30, 2020 08:18 AM
1arrowdown
Sep 1, 2014 10:56 AM
Dewd
XJ40 ( XJ81 )
Apr 17, 2014 08:48 AM
