What is this part?
Old Feb 17, 2013 | 07:54 PM
Diamondrmp's Avatar
Default What is this part?
I posted in the thread I started and didn't get a response. I need to find out ASAP what this part is so I can change it if possible.
What is the name of the round disk I am pointing too? Is it an expensive part and is it simple to replace?
Old Feb 17, 2013 | 08:04 PM
QuartzSTypeR's Avatar
Engine crankcase vent valve. Its like a PCV valve. Shouldn't take more than a couple minutes to replace.
Old Feb 18, 2013 | 02:36 AM
thebiglad's Avatar
Just as a matter of interest, why do you feel you need to change this part?
If it's starting to get blocked just take it off, rinse out thoroughly with paraffin and allow to dry, before re-installation.
Old Feb 18, 2013 | 09:37 AM
Diamondrmp's Avatar
Check out this thread.
Sulfur smell and rough idle
Old Feb 19, 2013 | 08:36 AM
Michael Star's Avatar
Old Feb 19, 2013 | 02:09 PM
Diamondrmp's Avatar
Do I have to purchase the hose also?
Old Feb 19, 2013 | 02:40 PM
Well I think it depends on if the hose has a hole in it or not. It is pretty easy to disconnect (squeeze it) but the end on the backside of the motor can be tricky to get to. Take it off and check to see if there are any leaks in it. I'd prob fill it up with water, hold a thumb over one end, and blow in the other to see if it squirts out anywhere.
Scott B
Oct 24, 2015 01:29 PM
wardo5757
Sep 11, 2015 11:31 AM
jaggermang
Sep 8, 2015 07:07 PM
DAN L
Sep 8, 2015 07:21 AM
1100me
Sep 7, 2015 06:26 AM
