What SC Belt are People using?
Old Mar 12, 2010 | 09:32 AM
fergs03R's Avatar
Originally Posted by crt_ben
jagv8,
If you need a belt the ebay one should fit - I'm running it on my 2003 STR right now, it works great! As far as I know, C2C26235 is the right part number for all of the old style (one sided) STRs. I don't think they changed anything with the supercharger belt or pulleys until the double sided update.
Just bouoght the belt...been the one that comes up most often and i have 03 STR so i pulled the trigger....
Old Mar 12, 2010 | 11:00 AM
crt_ben's Avatar
Cool - report back on how it goes! It would be helpful to have another data point. Hopefully this seller has a large supply so they're available for awhile - but that's why I bought 2, not taking any chances. I'll spend $30 now so I don't have to spend 250-300 to replace all the pulleys and idlers later on.
Old Mar 12, 2010 | 11:14 AM
Brutal's Avatar
Originally Posted by Riski
He does look rather cheap....wonder what he would charge for a crank pulley set up
Call him, cause last year when I had him make my pulleys ( for $175 custom)
I asked about a large crank pulley and how he did it since I didnt want to go without a factory damper. he then showed me 20 various BMW crank pulleys already done. He takes the stock one. machines the pulley off, and machines a new larger pulley to press fit and staked in its place. And voila' a larger crank pulley for more boost, better tahn a smaller blower pulley since as you drop size, you drop contact area and can lead to slippage. Plus you still have factory damper for harmonics reduction
MrWhite
19
Jun 14, 2022 07:49 PM
04Xjrsteve
May 7, 2019 04:06 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Col. Sandurz
Sep 28, 2015 07:29 PM
