Wheels
Old Nov 11, 2021 | 03:35 PM
fleen's Avatar
Default Wheels
what wheels fit s-type got a puncture and no spare its just to get car moved many thanks
Old Nov 11, 2021 | 07:17 PM
Hello,
Someone will be along shortly to direct you to the correct section where you can find help and advice for that and any other S-type questions you might have.
Welcome to the forums form ElinorB.
Old Nov 12, 2021 | 02:50 AM
Welcome to the forums fleen,
As you have a separate Intro thread, I've moved your question from New Member Area - Intro a MUST to S-Type forum. Members here with the same model will be able to help.
Old Nov 13, 2021 | 11:33 PM
Paul792's Avatar
Hi fleen
Below is the specs for the wheels. They appear to be all the same through the range of S types apart from the diameter of the rim.
– Center Bore: 63.4 mm
– PCD: 5x108 (5x4.25)
– Wheel Fasteners: Lug nuts
– Wheel Tightening Torque: unknown
– Thread Size: M12 x 1.5
– Trim Production: [1999 .. 2008]
Above is quoted from these links::https://www.wheel-size.com/size/jaguar/s-type/2000/
This link lists cars with the same wheel pattern. The X type is among the list if this helps. But as you go down the list things like centre bore are different on some models listed.
https://www.roadkillcustoms.com/whee...5x4.25-inches/
Old Nov 17, 2021 | 05:35 AM
neilr's Avatar
Many Ford and Volvo wheels would bolt on. Worth checking what you can dig up nearby.
HermanWiegman
Dec 7, 2020 09:12 AM
Steve W
XJ40 ( XJ81 )
16
Feb 29, 2012 09:06 PM
teflondon
Jul 3, 2009 01:29 PM
jbond007
Aug 14, 2008 08:30 PM
racerxf12004
Oct 4, 2007 07:02 PM
