During my heater hose replacement, I decided to change whatever was under the blower just so I didnt need to have to get back in there. That included the fuel injectors.
But try as I may, I couldnt find a set of fuel injectors that were identical to mine so I resorted to ebay and bought some that seemed to be appropriate. But I now think it was a mistake and will be pulling them out and putting my originals in after having them tested.
My fuel injectors look like
I KNOW these are correct. These are marked 6R83-BC from Denso
The ones I bought and put in look like these below and are marked 2W93-BA from Denso as well (obviously a different number but same connector, top and bottom and 12 hole output)
And came from this ebay ad https://www.ebay.com/itm/201820425788
the ebay seller claims they are for the supercharged 4.2L but i am starting to think they are not correct.
Anyone have any knowledge on what the green ones are for.
How about flow rates for the originals and the replacements?
I read a post on here where someone else used these green ones and toasted their motor so I am yanking ASAP. I would like some ammo to go after the seller to get my $369 back!
You know this already, but everything on the R fueling and engine management is unique to the R model or Jaguar supercharged models to be more exact....i would not think that there would be a lot of choices for injector replacements....i am thinking you got sold the wrong ones by the crazy trims you were getting....i have vin n67734...... 06 str ...i will see if i can see injector color on mine and post accordingly....i know mine are original....i was able to see the tops of mine...same red as your confirmed originals....hope this helps some
Reason: add
those green ones are exactly what my 03 STR has fitted .
they are 550cc Denso ,
I had mine ultrasonically cleaned and tested ,
with 170000km on them , and they tested perfect spray pattern. Equal flow and with no wear .
it Surprised me no end .
As mentioned above the injectors were changed at vin N52048. This is the start of the 06MY cars.
The correct jaguar part number for these later injectirs is AJ811177, these cost £146.56 each from Jaguar.
(When new in 2006 they had part number AJ88900)
I think before vin N52048 they were only available from Jaguar as part of the fuel rail assembly.
Mellow
Barratt's shows the early injector as currently available as a separate part, #AJ82532
Attached are images off of 2 different STR engines 03/04 are green, and ones on my 06/07 engine are red.
I recommend messaging AVOS regarding interchaneability of injectors. He worked a lot finding out the flow ranges and what injectors worked best in his modified engine.
Reason: Add another sentence
Get the original ones that are right for your engine and try to get your money back, you took a big risk with this ebayer, just the text alone would have given me the shivers: "Using a brand new Original Denso injector we have develop this upgrade unit to exceed original performance of the 2W93-BA
Numbers on our upgrade units have been erased to avoid confusion"
Yes it helps! Tells my I have the wrong injectors. Lets see what the seller says
Thanks so much for responding. Yes I shouldnt have done bought from this ebay seller. Too many things said these were not the right parts but I went on faith and tried them. Now I regret it and will be putting the originals back in. thanks again !!
