Will not upshift,stuck in 1st gear
Old Sep 26, 2016 | 04:18 PM
RobJ's Avatar
Default Will not upshift,stuck in 1st gear
Car idles fine with no engine codes. Park, neutral and reverse work fine. when put in drive or any manual shift car attempt to shift into second gear but then bogs down and downshift back in 1st gear and stays there. This fault happens everytime while attempting to drive, and I have no clue whats wrong. It is an 06 jaguar s-type with 3.0 engine 48,000 miles.
Old Sep 26, 2016 | 04:31 PM
JagV8's Avatar
First check the 2 small (8mm?) bolts that hold the shift cable to the trans side are there & snugged up.
If they are, probably time to check/change trans oil.
Old Sep 26, 2016 | 04:33 PM
RobJ's Avatar
Thanks, I already checked them and they are fine.
Old Sep 26, 2016 | 05:03 PM
RobJ's Avatar
The J-gate is not restricted and selects correct gear just doesn't accelerate beyond 1st gear
Old Sep 26, 2016 | 06:05 PM
Gus's Avatar
Gus
Check the adjustment of the of the shifter cable.
Gus
www.jagrepair.com
Old Sep 26, 2016 | 07:37 PM
RobJ's Avatar
The adjustment of the shift cable is good
Old Sep 26, 2016 | 07:48 PM
Gus's Avatar
Gus
I am going to bring it up again. I had the same issue with my xk8 ZF Trans and it was the improper adjustment of the shifter cable. I proved the Trans repair shop wrong when I did it myself. It could be a costly mistake.
Old Sep 26, 2016 | 07:52 PM
RobJ's Avatar
you sure my problem isn't just some type of limp home mode limiting it to first gear
Old Sep 26, 2016 | 08:03 PM
Gus's Avatar
Gus
Do this test. Put the trans shifter in #4 or #5 manual position and see if it shifts properly as you drive. No need to move the shifter the car will start in first and upshift automatically. Let us know your results.
Old Sep 26, 2016 | 08:12 PM
RobJ's Avatar
Car tries to kick in second gear still then downshift back into first goes no more than 15 mph. I still acts the same way consistantly
Old Sep 26, 2016 | 08:28 PM
Gus's Avatar
Gus
Now I am better understanding what you are experiencing. If that Trans wants to shift and does not then I would be looking at the trans control module and if I am correct yours is located in the trans. That trans control module takes information your engine and the engine control module. It sounds like it wants to shift and is unable.
Old Sep 26, 2016 | 08:57 PM
RobJ's Avatar
I have the tcm, pcm, abs checked already
Old Sep 26, 2016 | 09:09 PM
Gus's Avatar
Gus
The TCM and shifting valve body is in the trans. The TCM operates the shifting valves and if the signal is not correct or the valve is not working or the speed sensors are not reading properly it will not shift. Remember that the TCM & Valve body are one unit. How was the TCM checked?
Old Sep 26, 2016 | 09:20 PM
RobJ's Avatar
using jaguar diagnostic software
Old Sep 26, 2016 | 09:22 PM
Gus's Avatar
Gus
What did it tell you?
Old Sep 26, 2016 | 09:26 PM
RobJ's Avatar
the speed sensor don't seem to be out of range, voltage to trans looks good and nothing noticeably wrong with the shift solenoids unless you know specifically what I should be looking for in each sensor.
Old Sep 26, 2016 | 09:39 PM
Gus's Avatar
Gus
The valve body take a command from the transmission control module that takes command from the engine control module and that is governed by the operation of the engine. One of these are not working properly. If your engine is working properly at idle and revving then you need to look at one of the control modules or the valve body.
Remember this is not your father’s Buick.
Old Sep 26, 2016 | 09:53 PM
RobJ's Avatar
then I will hook it up to my computer and drive it an see what values I get when it refuses to shift
Old Sep 26, 2016 | 09:58 PM
Gus's Avatar
Gus
Are you using SDD or IDS?
Old Sep 26, 2016 | 10:57 PM
RobJ's Avatar
whats the difference between them?
