Wiper Blades
Old Apr 23, 2011 | 11:45 AM
vance580's Avatar
Originally Posted by Staatsof
That's not crazy sounding at all. Replacing with "refills" is a much fussier job and you need some needle nose pliers etc. You're exactly right Vance. Just remove them first and you'll be a much happier camper. Or, get a set of new blades. You still have to remove the washer hose if you have them though.
Do it once a year at $10 each time and you'll be just fine. I don't drive my car in the ice/snow so maybe the stock units suck for that. I know the car sucks in the snow so why bother.
I wish they sold refills in the stores like they used to at least around here. If I want just the refills I have to get them off the internet. I usually just replace the whole blade which is why I alway just take the whole arm off. Its just so much easier and dont risk messing anything up like scratching the hood. If I was to get refills I'd probably do those with the arms still attached.
Old Apr 23, 2011 | 08:10 PM
Staatsof's Avatar
No Napa autoparts where you are?
Old Apr 23, 2011 | 08:50 PM
vance580's Avatar
I have one Napa but its such a hole in the wall. They dont carry anything in their store except behind the counter parts. Its very small you just walk into a door right to the counter and everything I've ever asked for has to be ordered. If I have to order it I'd rather just get it off the internet cheaper and have it shipped to my door. Probably the worse NAPA I've ever been too. The one where I used to live was really nice.
Old Apr 24, 2011 | 04:35 PM
Dmax's Avatar
Default Wiper Blade Replacement--Ebay
Ok.let me get this straight on the Piaa blade inserts.I can go to Amazon and get the 19 and 24" inserts which are run as one item for about $15.00.There isn't info on width. Has anyone ordered these? Are they 6 mm claw width? Trying to find out if they will fit before I order.;.
Old Apr 25, 2011 | 10:57 AM
Jon89's Avatar
The PIAA 19-inch passenger side insert is a 6mm claw width, so it will fit the factory arm. However, the PIAA 24-inch drivers side insert is an 8mm claw width, so it will NOT fit the factory arm. I've spoken with PIAA headquarters and asked them to make a drivers side insert in a 6mm claw width. PIAA has the best wiper inserts I've ever used....
Old Apr 25, 2011 | 01:38 PM
Blue Lion's Avatar
Originally Posted by The Chris X
I got PIAA blades from TireRack.com. They have the aero spoiler on them like the OEM blades. I found nothing out of the ordinary as far as changing them goes - just took a small screwdriver and popped the clip and it was off.
I was about to order from Tire Rack (thanks for the info), checked Ebay who was higher, but Amazon.com was $10 cheaper out the door due to free shipping. Items were the same price as Tire Rack.
Old Apr 27, 2011 | 05:17 AM
Blue Lion's Avatar
Default Piaa
got the blades already and they fit perfectly on my 03. Thanks Chris.
Old Apr 27, 2011 | 05:37 PM
  #28
Blue Lion's Avatar
I got mine from Amazon for my 03 4.2L and they fit fine. It was the 95060 and 95048. Around $40 total with free shipping. Got them the next day.
Old Apr 27, 2011 | 05:45 PM
Pushing_Tin's Avatar
Okay since I just removed my entire windshield cowling I decided to replace the wipers since they were already off. I ordered these from Nalley a few months ago. The driver's side appears to be indentical to the one I have now, but the passenger side has this little nipple on it. Is this for the later cars?? I also can't figure out how to get them off of the arms... The little nipple thing is near my thumb.
Old Apr 27, 2011 | 07:14 PM
  #30
Well I got the driver's side replaced after messing with it for an hour. I managed to break the clip but I think it will hold. I also scraped the **** out of the arms so I will probably need to repaint them. Ugh.
The passenger side I cannot get on all the way. Is there any difference in the way these fit from the earlier models? Mine does NOT have the wiper sprayer.
Old Apr 27, 2011 | 08:43 PM
  #31
vance580's Avatar
Thats the washer nozzle. Those blades are for the 05+. Thats how the 05+'s look you would undo the tube going into the barb fitting and slip it on those. The 05+'s dont have the washer sprayer on the hood like your 03 so thats what they did and why its so hard for some guys to get blades because the stock ones dont come off so you can only replace the insert. The previous owner of mine somehow found removeable sprayers so I can switch out the entire blade.
Old Apr 27, 2011 | 09:47 PM
  #32
So should it fit? I couldn't get it to fit, but that doesn't really mean anything.
Old Apr 27, 2011 | 10:46 PM
  #33
jag79's Avatar
This is what I have on my 03' STR......."MICHELIN Stealth Hybrid Wiper Blade", It replaces the OEM metal brackets, much cheaper than the OEM's, and real easy to install
link
http://www.pylonhq.com/products_mich..._details.shtml
Pics: Pylon - Stealth Images
Sizes:
DRiver: 24
Passenger: 19
Old Apr 27, 2011 | 11:06 PM
  #34
vance580's Avatar
As far as I know it should fit. It will just have the sprayer on the mount. Other than that it should just be the same as other wiper.
Old Apr 28, 2011 | 08:44 AM
  #35
JOsworth's Avatar
Yea, they sent you a 05 blade....
03 and 04 use the same size blades (I'm pretty sure) but check... I think the 2000 to 2002 cars use 21" blades for the driver's and passenger's side. The 03 and up cars use 24" driver and 19" passenger (again, I'm pretty sure but typing from memory). The only difference between yours and the 05 and up wipers is the mounting clip. The 05 and up clip has the washer nozzle attached while the 03/04 clip is standard. So, to remove the clip just push it off from the bottom. You will see that it mounts on a pin so it just snaps off and on. It is a tight fit so it will take some force.
Now you see the frustration that 05 and up owners face... That clip, while it does un-snap, WILL NOT fit into an aftermarket solid blade, no matter who made it.
You are at an advantage with an 03.. You can just get any aftermarket blade in the correct length and snap it onto the hooked wiper arm.. 05 and up owners..no such luck... Unless you get those UK blades in this thread with the wiper nozzles mounted...
Old Apr 28, 2011 | 11:29 AM
  #36
vance580's Avatar
I have those clips in a set of Ancos on my car right now. Or are you talking about the solid aerodynamic style blades.
Old Apr 28, 2011 | 05:10 PM
  #37
JOsworth's Avatar
Yes, that is what I meant.. I thought I said "solid" blades in my post..
Old Apr 28, 2011 | 05:48 PM
  #38
vance580's Avatar
You did that was my fault and I'll accept my flogging. LOL. I did see some I'm going to try that are the solid aero style that are listed for the 05+. I'll report my findings once I get them.
Old Apr 28, 2011 | 07:36 PM
  #39
JOsworth's Avatar
Ha Ha.. That's funny... Hey, before you spend any money, check with me, I test fit a bunch of different solid blades in an attempt to adapt the clip. I'm sure there were a couple I missed, but not much...So, just PM me what you want to get and I'll let you know if I tested them or not..
Old Apr 28, 2011 | 08:18 PM
  #40
vance580's Avatar
Will do I'll let you know when I get up to the store since I dont remember what brand they were off the top of my head right now. I'm detailing my STR tomorrow, for Cars and Coffee, so gotta go up there anyways so I'll make sure to write down what blades they are then.
