Gearbox whine
Old Apr 2, 2018 | 10:55 AM
Chas Dougan's Avatar
Default Gearbox whine
F-type 2.0 Ingenium engine, has developed a low pitch moan or whine around 1500 - 2500 rpm, especially noticeable when slowing down gradually through the gears (automatic box). One of these noises you can't quite put a finger on, does not do these when revving slowly through the revs when in neutral, hence think it is in the transmission. Any help?
_______________
2017 F-Type (added by GGG)
Old Apr 2, 2018 | 05:09 PM
Welcome to the forum Chas,
I've moved your question from UK & Eire Region to F-Type forum. Members here with the same model will be able to help.
Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Apr 2, 2018 | 07:22 PM
Unhingd's Avatar
_______________
Does the frequency of the whine change when you shift gears, or does the frequency depend entirely on the road speed. If the former, you have a transmission problem. If the latter, it’s a differential problem.
Old Apr 3, 2018 | 03:42 AM
It does not seem to depend on road speed as such and is most noticeable when, say, you decelerate slowly, without braking, and as it changes down through the gears the noise comes in at the rev. range around 1500 to 2000rpm. You can only hear this when the engine, itself, is relatively quiet, that is, if you accelerate the exhaust noise will drown it out (it probably is still there, though!) At those revs the frequency of the "moan" stays the same. If it helps, the perception is that the sound seems to emanate from the front of the car on the passenger side.
Thanks for your interest.
Old Apr 3, 2018 | 05:52 AM
Unhingd's Avatar
WAG: Input shaft bearing.
Old Apr 3, 2018 | 11:22 AM
Booked the car in today for them to look at this, they can't take me until May 1st.! - must be a lot of Jags needing attention! I will print out this thread to see if it helps diagnose.
Old Apr 3, 2018 | 01:55 PM
Unhingd's Avatar
Where are you located? Time to find a new dealer. A one month wait seems to be excessive.
Old Dec 23, 2018 | 10:03 AM
Yoosey's Avatar
Hi, getting a silmilar whine from my X350. Did you get yours sorted? If so, what was diagnisis?
Old Aug 28, 2020 | 04:53 AM
Nuno Miguel Monteiro's Avatar
i had the same problem in my f-type 2.0.
the whining is more notorious in 104 to 115km/h in highway.
Jaguar after 10 days of analsys say its the eletronic DIF, and order new one under waranty.
Can you all write what was your dealer resolution ?
Old Aug 28, 2020 | 10:39 PM
Unhingd's Avatar
The 2.0 has an ELSD like the 5.0?
Old Aug 29, 2020 | 03:02 AM
bjg625's Avatar
I don't think 4 banger has any LSD.
Old Aug 29, 2020 | 04:00 AM
JacksonvilleJag's Avatar
No limited slip differential on the 2.0
Old Mar 12, 2026 | 04:13 AM
karloefc's Avatar
Default Droning noise present between 1500 and 2000rpm
_______________
Hi im very new to this forum i have a P300 R Dynamic 37k on the clock. I have the exact same issue as you have described. Its driving me mad and I cant fully enjoy driving the car. Did you ever get to the route cause of the noise please. Thanks
Old Yesterday | 09:03 AM
cptpies's Avatar
I'm new to this forum too and used it to look up the symptoms because I had the same whining issue with my 2021 P300. The issue in my case, after the car spending 3 weeks at the dealership while they diagnosed it, was found to be a coolant leak into the transmission having caused corrosion. Fix was a whole new transmission, luckily under warranty otherwise you are looking at about £9000 for new one and labour to install. So if you haven't fixed this yet the key test they did was testing for Glycol in the transmission oil. Knowing that might save you a 3 week wait while they scratch their heads then call JLR Technical Assistance for help, who solved it in a day.
yardbird
Nov 13, 2016 03:11 PM
hunucru
Jul 22, 2008 04:01 PM
Bigal1941
Jul 9, 2008 01:57 PM
Glennbow
May 8, 2008 05:36 PM
JimC64
Apr 13, 2007 10:22 PM
