SVR Wheels - Are both designs forged?
Hi there
I am planning on getting another set of wheels for my SVR, my car currently has the satin grey forged SVR wheels which are quite light in weight.
I can get a set of the ceramic brake SVR wheels for a good good price, the diamond cut ones, but I can't see any mention if these are forged or not and if they weight more or less than my current SVR wheels?
The plan is I shall run one set with PS4S for cooler months and the other set with cup 2's for track days and Summer months.
I just wondered if both types of SVR wheel run the same offsets and if they are both forged?
But the SVR had updated wheel design for ceramics and I am not 100% sure if they are forged or not. I know the SVR wheels for none ceramic equipped cars were indeed forged, which is what I have.
The US MY17 brochure (same as UK MY16?) lists both SVR wheels as forged alloy, but of course, it doesn't list weights...
http://www.auto-brochures.com/makes/...-Type_2017.pdf
Received 3,260 Likes
The carbon fibre inserts weigh next to nothing but of course they are purely decorative.
The forged Storm wheels (T2R10299/T2R10300) are heavy. I weighed mine and they are heavier than the cast Gyrodyne:
- Storm: F:35lbs, R:39.8lbs
- Gyrodyne: F:32lbs, R:34.2lbs
Forged doesn’t automatically mean lighter. Depends on the wheel design. Both Coriolis and Maelstrom wheels for the SVR are forged. I’m interested to know how much they weigh.
I did weigh my SVR wheels, but I cannot find the photo I took, but if memory serves me right my SVR (none diamond cut ones) were 12kg (27lbs) for the rear wheel.
The seller on SVR diamond cut wheels has replied saying the rear wheel is around 13.5kg (30lbs).
Once I get these I shall weigh them without and with tyre.
Then when I remove the others I shall weigh without and with tyre also for comparison.
I was looking at Vertini Flow Forged RF series and contacted the manufacturer. Was told they were 20-24 lbs ea. depending on style for 20 inch. Was told their Vertini/Stance forged series could be up to 5 lbs lighter.
For street driving, would a 10 lb reduction in unsprung weight be noticeable in driving dynamics? For those of you with the Wortec rotors, some commented that the driving difference was noticeable, and as I recall that weight drop wasn't as significant? By the way, both of these wheels are reasonably priced. Gibbo, I can start new thread if hijack in process.
You notice unsprung mass reduction the most on ride quality and I'd say a driver who is quite aware and feels slight changes in their will be able to feel an improvement with just upto 2kg per corner shaved on ride quality.
You may also notice improvement on turn in and agility.
Acceleration I doubt you will notice to be honest.
When I fitted the brakes the ride quality difference was very noticeable and the cars agility.
Of course when you save weight with wheels it tends to be even more noticeable simply due to the larger diameter.
jaguny (09-25-2018)
This has me wondering about the true weight savings of the carbon ceramic brake package with the Storm wheels. The brochure for my car (2015 model year) states, "offering up to a 46 lbs weight saving." This could well mean a 46 lbs. weight savings when compared to a car equipped with the heaviest wheel type offered (don't know which one that would be) and the heaviest conventional brakes (probably the super performance brakes). If it simply means 46 lbs savings on the brakes alone, the Storm wheels apparently sacrifice some of that savings (compared to the Gyrodynes and possibly other F-Type wheels).
That was why I jumped on the Wortec option - combined with lighter aftermarket forged wheels, I've knocked at least 100 lbs of unsprung weight (double what the CCB save) and for about the same money get better looking wheels that don't require spacers. BTW, I'm not knocking the CCB, I'm sure they offer superior stopping/fade, its just for my uses factory brakes are adequate, I was more interested in weight savings and appearance.
Now remember an SVR comes with forged wheels whether you take ceramics or not.
So I suspect the 21kg saving you get by selecting ceramics is mostly in the ceramic rotors as the calipers on ceramics are bigger but lighter, plus you have the additional handbrake caliper assembly too. So its probably safe to safe the ceramic rotors probably save around 25kg, but some kilos get added back in from the bigger calipers and also maybe the ceramic optioned SVR forged wheels are maybe a touch heavier too.
RIRR (09-25-2018)
That was why I jumped on the Wortec option - combined with lighter aftermarket forged wheels, I've knocked at least 100 lbs of unsprung weight (double what the CCB save) and for about the same money get better looking wheels that don't require spacers. BTW, I'm not knocking the CCB, I'm sure they offer superior stopping/fade, Its just for my uses factory brakes are adequate, I was more interested in weight savings and appearance.
Well on a SVR I think they state ceramic brakes save you 21kg, over regular ceramics.
RIRR (09-25-2018)
I recall seeing somewhere (brochure or specs online) Jaguar stating they are forged. There is also a cast version, but the black with diamond cut spokes that came with CCB vehicles along with the gloss black ones are forged.
They are smooth on the backside of the face and the markings are engraved.
The advantage of the forging process is added strength and structural integrity, which allows the wheel design to use less material to reduce weight. The fact that there is also a cast version of the exact same wheel design should have been a clue that they are heavy, but I missed it.
