Aiming for 10.5 1/4th mi !
Old May 11, 2025 | 06:07 PM
AlexJag's Avatar
Sponsor
Default Aiming for 10.5 1/4th mi Alpha Jag!!!
Just a teaser for you guys! ! !
2018 F-Type R, lower /upper pulley, all our custom ECU /TCU tuning, the rest is stock including OEM cats, wheels and supercharger.
Alpha Jag all the way!!!
And yes I let off at 1000ft
More in works!!!
Old May 12, 2025 | 05:06 AM
Gasman2's Avatar
That’s a great achievement with just pulleys and a tune
you will def get to 10.5
either a ported charger or a 2300
watwr meth
fi interchiller
this will ensure rock solid low iat and mat
Old May 12, 2025 | 02:25 PM
AlexJag's Avatar
Sponsor
watwr meth
fi interchiller
Thanks! And no need for 2300, plenty of power left from our 1900s, most likely more than our engines and transmissions are capable of handling!
Old May 21, 2025 | 04:23 PM
AlexJag's Avatar
Sponsor
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old May 23, 2025 | 09:23 AM
SVR727's Avatar
Just started a thread about pully and tune for an SVR.
Looking to still be 100% street and almost daily car as well, how is yours for that type of use? Are the tunes canned or on-site assume only?
Old May 26, 2025 | 10:49 PM
AlexJag's Avatar
Sponsor
At Alpha Jag Tuning we have been tuning 4.2 , 3.0 and 5.0 engines for quite some time and set records before and now this latest record on FType R and with minimal mods..
Definitely properly tuned car will drive with no issues as a daily driver, when you step on it is when you will
notice the extra power and with custom tuning lots of parameters can be fine tuned to your liking.
I have 3 Jaguars that I drive, XKR, XJ SC 5.0 and ftype-R
All tuning that we do is custom and is according to data logging and is easily done remotely with our tools
Feel free to reach out www.alphajags.com or www.facebook.com/alphajagtuning
__________________
Old Oct 10, 2025 | 02:30 PM
AlexJag's Avatar
Sponsor
Default Finally flat 7.0 1/8th mi on the F-type!
Update : Even faster yet ! Still let off because no room where I test the car .
Still stock exhaust and weight
Old Oct 11, 2025 | 07:17 AM
SuperchargedFresh's Avatar
what’s your numbers for the 3.0 aj126 motor?
Old Oct 17, 2025 | 01:36 PM
AlexJag's Avatar
Sponsor
Not much data on v6 for now, but you can bet it's going to be good😁
Old Nov 29, 2025 | 07:00 PM
AlexJag's Avatar
Sponsor
Default Fastest F-Type R
Currently fastest ftype r with minimal mods and no nitrous
This was on slow high da track too
__________________
Old Feb 26, 2026 | 01:43 PM
AlexJag's Avatar
Sponsor
Default Best time yet 10.7 1/4th
Update:
Took the car to another racing event by Bakersfield CA! Unfortunately heavy fog and 40 degrees weather all day made the track slippery for the AWD cars since we can't do a proper burn out on street tires. Nonetheless even with loosing .15sec on takeoff managed to get best of 10.7 and 131MPH trap so now that's a new record!
Happy with that even those car does have 10.5 in her!
Stay tuned!
Jaguar & Range Rover Performance Tuning | AlphaJagTuning
Old Apr 6, 2026 | 04:14 PM
AlexJag's Avatar
Sponsor
Went to a local drag race strip last Friday . It's only a 1/8 mile and density altitude was 2000+ , nonetheless car ran pretty strong! Still full factory exhaust with cats!
__________________
Old Apr 7, 2026 | 07:25 AM
ER9240's Avatar
What tires are you running (maybe I missed it), and how are you launching to get your 60’ below 1.7?
Impressive numbers. 🤙🏼
Old Yesterday | 03:25 PM
AlexJag's Avatar
Sponsor
Default AlphaJag tuned F-Type R does 10.6 quarter mile!
Getting close to that 10.5 , and nonetheless fastest F-Type on record without Nitrous!
Four runs all 10.6 range ! Same mods , stock exhaust and cats!
__________________
Old Yesterday | 05:20 PM
ER9240's Avatar
How are you setting up the car for launch and what are you doing to get it off the line?
Old Yesterday | 11:34 PM
AlexJag's Avatar
Sponsor
Nothing special 😉 no offense but if we tuned your car would give you all the tips in the world! If you look at the trap speeds and compare to yours for example you would see it's putting down a bit more power than yours, so it's not exactly in the launch .
__________________
Old Today | 12:57 PM
Stohlen's Avatar
I launch off idle (no brake torque, just mash the gas on green) and get a 1.65x 60' time.
Rfranke31
May 12, 2025 09:18 AM
Joel Brown
40
Nov 5, 2021 09:30 AM
Joel Brown
Jan 4, 2021 08:38 AM
Terrance39
Nov 26, 2019 10:56 AM
GhostriderXKR08
Nov 19, 2013 05:24 PM
