2011 XF dead battery replaced now won't recognize keys
Old Jan 7, 2026 | 01:53 AM
Jeremy noor's Avatar
Default 2011 XF dead battery replaced now won't recognize keys
I bought a 2011 Jaguar XF from the auction it had a dead battery came with one key so I got another key programmed tried to start it put a new battery in the car and new battery in the keys but the car won't recognize the key it'll lock and unlock the doors but the button in the center doesn't work so I use the slot and the slot says check smart key so the car is not recognizing it so my mechanic said KVM BCM problem so when I got a new BCM and he programmed it and then I got a new TV how many programmed and put it in and it's still not recognizing either of them and still saying checks smart key I can't start the car whatsoever it doesn't recognize the keys so I called another locksmith he came out and made me two more keys and he tried programming it nothing so I've made four keys now change the KVM BCM had it all programmed I still get nothing any ideas or anybody can help me possibly
I am in downtown Los Angeles I need to text that can help me ASAP they're going to tow the car any day
Old Jan 9, 2026 | 03:00 PM
dennis black's Avatar
20 Year Member
Start with the basics check if the battery is at 12.6 or greater. Then we can start diag
Old Jan 10, 2026 | 05:57 AM
Jda600's Avatar
Check on this site for JLR Tech - he is on the West Coast however he was able to reprogramme my XF keys remotely when I was in Texas.
Old Jan 10, 2026 | 12:05 PM
OneDriver7's Avatar
get a mongoose JLR cable from eBay. Download a version of SDD. It’s on the forums, just search. I know everyone is going to say get a battery maintainer, however I didn’t have the money to buy one when I had this issue. You will need to atleast connect to another car using jumper cables. I hate worked for me, was to go into SDD and replace Control Junction Box as new. I didn’t actually replace the part. I only ran the module. When this happened I was able to link my only key and a spare key that I bought off of eBay all at the same time
People are going to loose their mind over what I told you. Because technically you should use a battery maintainer, but like I said, I didn’t have the funds and it worked for me. 2013 jaguar XF AWD
Old Jan 10, 2026 | 05:05 PM
Jnoor86's Avatar
Yes battery is at 12.6 volts exactly actually just came in from trying to mess with it and figure something out so the battery is good but I was looking at rear fuse box in the trunk and it seems like there are things missing or unplugged possibly I see some extra wires as well not plugged in I bought it at auction so maybe they had to replace all the electrical and didn't put it back right possibly and it never ran again so they let it get towed because it looks like a lot of the parts have been changed literally like everywhere I look you can tell it's been removed or replaced so that has to be my problem I am checking all of that compared to the factory stock diagrams
Old Jan 10, 2026 | 05:06 PM
Jnoor86's Avatar
Old Jan 10, 2026 | 05:57 PM
20 Year Member
Second question is the BCM/KVM brand new from JLR,
also do you have a image of your trunk
Old Jan 18, 2026 | 05:46 PM
I will supposed to pick immediately ASAP
I will post a pic immediately ASAP thank you
Old Jan 19, 2026 | 06:43 AM
John Williams's Avatar
You need somebody to run immobilisation in SDD to reprogramme the keys.
Old Jan 24, 2026 | 04:02 PM
vfrman's Avatar
This.
Old May 30, 2026 | 07:19 AM
Tattoosbykevinjohn's Avatar
Can you please explain what you mean by this? I also have a no key issue. Hooked up a battery charger and was cranking my car with my battery too low and now my car says smart key not found.
Old May 30, 2026 | 09:56 AM
clubairth1's Avatar
Community Influencer
Do you have an operating SDD system?
This will be required to fix your car.
Old Yesterday | 02:56 AM
So I'm brand new to the Jaguar world. I'm still green and have much to learn. To clarify a operating SDD system from what I'm understanding is a Diagnostic tool capable of accessing the Jaguar obd2 port or what exactly are you referring too? Is there a way you can post a link to what I would need to get. My budget is limited or else I would take it directly to Jaguar. But I'm mechanically inclined and am trying to learn. So if you can dumb it down a little for me until I get more hands on experience I would be forever thankful
Old Yesterday | 09:45 AM
clubairth1's Avatar
Yes since your new you will need to study this a bit and decide what you want to do. It's "THE" diagnostic tool and is what JLR dealers used back when these cars were new. Never released to the public and was only meant to be used by factory techs. So the software is free (Sort of it's all copied from JLR) and the interface cable is not and that's another bunch of decisions you need to make because there is not just one cable but several different interfaces that can be used.
SDD - Symptom Driven Diagnosis. Uses a laptop and a USB cable that interfaces with the OBD port. Special software (Another set of decisions will be what operating system you want to use and whether you will use a VM or not). It's old software and many are running it on XP! I run Win10 and no VM. I use a cheap dedicated laptop that does nothing but SDD work. Be prepared to install SDD several times before you get one that works for you. Again there is a whole list of things that can go wrong or done differently.
Also requires a stout DC power supply to power the car while it's being used. So do understand what's required to run this. Plus there are multiple versions of SDD. I currently run V167.xxx and it works fine on my 2014 XJR.
It's also awkward and difficult to use mainly because we were not sent to school on it like the JLR tech's were! The level of difficulty will be related to your computer skills. I am old and struggled but got it working with the help of this forum and you can too with a bit of time and effort!
Here is a quick search on SDD. It returned over 400 threads. The mods have requested that we try to put the SDD stuff all together because it is such a big subject.
SDD Threads
It's not easy or quick to set a system up but I have not found anything that can do what SDD can.
So read a bit and do post some questions to those existing threads and decide if you want to spend the time or not.
Finally understand that to JLR SDD is long obsolete and not in use anymore. So expect no help from any dealer.
Old Yesterday | 05:16 PM
SDD Threads
Okay so I think I'm understanding correctly. I have a laptop I can use. So I would need to go download the SDD software. Is there a link or something you can post to the one you use that your having luck with. And also what cable should I order? So basically I'll research deeper into this I would just like to get the cable ordered today as the car has already sat for months this is by far the best route I could of taken is this forum. I would of been in here months ago. Thank you so much dude. You have no idea the standstill I been in.
Old Today | 10:58 AM
clubairth1's Avatar
Again yes but that's all contained in the existing threads I linked. There are no short cuts here. Do some studying and then try what you think will work for you.
Make sure that the laptop does not have anything of great importance on it. You may well be wiping and installing several times. Don't listen to anyone who claims SDD can only be run a certain way. That's just not true and the many variations is another set of decisions you will need to make.
I use a "Mangoose" which is a chinese clone cable of the old Drew Tech. Mongoose cable. This is only one of several devices that can be used. Many, many problems with these but so far mine has worked just fine. But as I posted there are multiple kinds of interface cables.
You can see that every decision leads to other decisions! But if you keep at it you will be able to do it as many of us have. I spent several months building and rebuilding my SDD laptop.
Oh and watch out for British Diagnostics. They offer SDD cables and software. I have never used them but had in the past recommended them. BUT we have had a number of forum members get terrible service from them and I now do NOT recommend them.
Armand
E-Pace
Jul 22, 2024 09:08 AM
John316xx
Jun 27, 2022 12:24 PM
L Timmons
Jan 2, 2021 07:18 PM
car5car
May 1, 2020 08:29 PM
Zdenek Schneider
Nov 5, 2019 04:06 PM
