Help! Help! Help! 09 Jag XF 60k mls
Old Jun 25, 2022 | 05:16 AM
John316xx's Avatar
Default Help! Help! Help! 09 Jag XF 60k mls
2 PROBLEMS
1st issue: Over the last 2 years the car would start perfectly sometimes. Other times I would attempt to start it 2 4 6 8 times before the car started.
2nd issue: Last week the car wouldn’t start and I flattened the battery, immediately the car wouldn’t lock, neither would the car recognise the key in any way and says; “Check Smart Key”
  • I have charged the car battery
  • I have put a new battery in the smart key
  • I have inserted the smart key into the slot
RESULT: Nothing other than, “Check Smart Key”
I cannot plug a computer in as the car doesn’t recognise the smart key.
Any suggestions?
Old Jun 26, 2022 | 03:31 AM
POD XF's Avatar
Running the battery down with a difficult start seems to induce all manner of errors in these cars. First thing I would try is disconnecting the battery terminal and then reconnecting, this often resets the security system.
I have read that with the battery disconnected, touching the positive and negative cables together resets error codes; I think (not certain) that I have done this successfully in the XF at some stage but can't recall what error I was trying to clear.
Old Jun 27, 2022 | 10:14 AM
Splint's Avatar
+1 to touching terminals together with battery disconnected, I wouldn't do it too often though heard it can confuse ecu.. also remove battery earth from car body end and sand or grind the paint from under the main earth cable. Solved quite a few of my issues. Do the same for any other earth cables you find under bonnet etc.
Old Jun 27, 2022 | 12:24 PM
clubairth1's Avatar
Community Influencer
Do you have only one key?
If you have another does it do the same thing?
mdk2000
Jan 14, 2025 02:33 PM
jakesdad
Mar 19, 2021 06:48 PM
L Timmons
Jan 2, 2021 07:18 PM
AnneG
Aug 5, 2017 11:25 AM
Bagar
Nov 15, 2013 09:35 AM
