What settings will I lose on my 2013?
Old Today | 04:45 AM
alanroberts50's Avatar
Default What settings will I lose on my 2013?
I saw this suggestion in another thread regarding resetting the centre brake light by disconnecting the pos cable on the battery for 30 seconds and want to try it but before I do I am curious as to what settings I will lose, if any?
“So, it may look as though CHMSL is dead (all LEDS out), but it is because you have no output from CA129-9. The only way I have found to reset the output is to disconnect positive battery terminal for 30 seconds....when you hook it back up, waalaa, CHMSL lights back up”
Alan
Old Today | 06:46 AM
JagV8's Avatar
Likely to lose all learned values (fuel trims, OBD monitors will reset so you would fail smog, etc) and window settings I expect.
Old Today | 06:47 AM
guy's Avatar
guy
Performing a reset is an annual occurrence for me.
All of the reset operations are covered in your owners manual. These include
engine adaptations, window reset, seat reset.
And gives you the opportunity to enjoy an Italian tune up.
Old Today | 07:53 AM
Thanks, I can live with those. I do recall Cali smog being a pain after OBD monitors refused to reset on my xk8 but not an issue here in South Africa thankfully!
Old Today | 08:53 AM
Ok did that but no difference to the boot brake light, will just be a nice fancy refector from now on I suppose.
Old Today | 08:55 AM
hey Guy may I ask your reasoning for an annual reset? Sounds fair to me just curious
Flyboygus
Nov 3, 2023 08:25 AM
Littlefoot2
Mar 22, 2023 04:35 PM
skidman
Dec 20, 2022 10:42 AM
CJSJAG
Nov 5, 2021 08:30 PM
Pompa
May 27, 2021 12:20 PM
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
