I know it seems incredible, but almost ten years ago my Specialist Jaguar Garage replaced my radiator and oil cooler thing apparently because of a sheered bolt or similar excuse, I don't exactly remember. Anyway ever since then my cruise control reports that it is unavailable. The ASL works fine, which is what I use most of the time to avoid tickets, but up until recently I've hardly ever needed to use the cruise control. However now things have changed and I would like to have it operational. I would really be most grateful if anyone can please tell me if there's an accessible plug & socket that the garage may have failed to connect properly which I could check or perhaps cable damage or indeed if there's an easy way to detect if the cruise module has failed. It does seem a little strange that it would fail whilst in the garage for radiator repairs. The garage seem unable or unwilling to investigate. Thanks loads.
The only thing I can think of that's down at the front of the car is the adaptive cruise control - which your car may or may not be fitted with - although I'd expect a failure there to throw an ABS message.
Can you check for any DTCs that might give a clue?
Oh I quite often get intermittent "ABS" & "DSC System Fault" messages, especially in the rain, which go away in their own, but these seem to have ceased since I solved my MAF issues. There are no current codes or messages, just no cruise control and a message saying "Cruise Control Unavailable". The front end was modified some considerable time before the cruise control died (See photo) so I don't think that's the cause. I just thought that if the garage were messing around with the radiator etc. they might have dislodged a connector or similar. That garage, which went bust some time ago, appears to have caused all sorts of other problems, which over time have steadily been solved, but this one is still outstanding.
