XJ40 ( XJ81 ) 1986 - 1994
6.0 Litre - Various Issues
Old Yesterday | 06:33 PM
V12Lover's Avatar
Default 6.0 Litre - Various Issues
Hi together,
in addition to my transmission my engine is now starting to tackle me.
1. Issue: the left hand catalytic converter is melted inside
2. Issue: the ignition coil of the left hand bank is slightly burned (probably caused by someone not putting on the ignition wire properly) -> this could possibly explain #1
3. Issue: on the right hand bank 4 out of six spark plugs are almost white, which would indicate they are running too lean
4. Issue: the oil consumption has increased over the past year, it is at about 1 litre per 1000km
Regarding issue #1 I have been looking for a replacement, but there are only cheap aftermarktet parts available which are said to be made of poor quality, can anyone tell me a source for a good replacement?
Issue #2 should be fixed by a new coil and cable, luckily.
Regarding issue #3 I have tested 2+2 injectors (2 from cylinders with good spark and 2 from cylinders with bad spark) and they tested almost equally (amountwise). So the injectors are probably not the issue. So do I also have an ignition issue on the other bank?
For issue #4 I made a compression test and found that the rear cylinders of each bank are slightly below the factory value (between 12,5 bar and 13,2 whereas the target value is between 13,6 and 16,3 bar). So I guess the cylinder head gaskets are about to give up. Or has anyone a better explanation?
Doing the head gaskets is quite a job according to what I have read so far, but paying someone for doing this is not an option. Looking at my faulty transmission I am not sure if am willing to take the task, knowing that even when it's done I am still in trouble on the other side of the crank. If I knew the transmission was fixed it would increase my motivation to do the engine as well, but if it turns out that is more serious that just the head gaskets, I might have fixed the transmission for nothing.
Any thought appreciated.
Oliver
Avalianteffort
Oct 16, 2021 09:58 AM
Norcat
Aug 21, 2021 12:34 PM
tommaso
Jan 16, 2017 09:04 PM
ross1
Jan 10, 2012 10:22 AM
davidireland
Jan 28, 2010 07:53 AM
