XJR6 Fuel Consumption Excessive
We all know the only thing an XJR6 cannot pass is a gas station.
However, mine is drinking excessive amounts of fuel. Spark plugs look sooty (NOT due to oil consumption).
Wallet is looking anorexic.
Suggestions on possible causes?
The engine regulation ( mixture or short term fuel trim ) must go into closed loop by seeing the engine coolant temp reach 165 degrees C abouts
Try changing the very cheap ECT sensor that can be calibrated against a chart on page 78 of the 801s doc
801S TITLE
If you ever change the thermostat , never install the large O - ring even if it comes with one , cracks the casting ears
801S TITLE
