Jaguar XJ 20102019 Upgrade 13" Android Screen with CarPlay & Modern Infotainment
Hi XJ owners,
Were CarpuTech, a professional manufacturer specializing in infotainment upgrade solutions for luxury vehicles. If youre driving a Jaguar XJ / XJL / XJR (X351, 20102019) and want to modernize your interior technology while keeping the classic luxury feel, this upgrade is designed for exactly that.
Weve developed a 13" Android touchscreen system specifically for the XJ platform, bringing modern connectivity and a much improved user experience without changing the original elegance of the cabin.
📱 Apple CarPlay & Android Auto seamless access to navigation, music, calls, and apps
🧠 Android system built-in install apps like Google Maps, YouTube, Spotify, Waze, etc.
🖥️ 13" HD touchscreen upgrade larger, clearer, and more responsive than factory display
🔄 Retains OEM Jaguar system switch between original interface and Android anytime
🎵 Supports factory audio system keeps original sound quality and amplifier integration
🎮 Maintains factory controls steering wheel buttons and original functions still work
🎯 Plug & Play installation no cutting wires or complex coding required
🧭 Built-in GPS navigation modern navigation experience with real-time traffic apps
This upgrade is ideal for XJ owners who want to bring modern infotainment features into a full-size luxury sedan without compromising Jaguars original design language.
The X351 is still one of the most elegant luxury sedans on the roadthis upgrade simply brings the tech up to todays expectations.
If you have any questions about compatibility, installation, or real-world performance, feel free to ask 👍
CarpuTech Team
__________________ Carputech is a manufacturer dedicated to providing OEM factory-integrated navigation systems(Carplay Upgrade Modules), Carplay adapters, and aftermarket CarPlay/Android Auto systems for various vehicle brands. Web : www.carputech.com E-mail : support@Carputech.com Welcome any inquires. Thank you.
Does your unit keep the factory OEM cooling fans running? Pushing air thru the factory duct and on the back of your unit?
This is critical for any aftermarket screen install.
Usually this requires the aftermarket screen to swap over 2 PCB's from the stock unit. Otherwise no fan operation and the the aftermarket screen will get hot and overheat. We have had several members buy theses type of units without the card swap and then had problems.
Hello, thank you for your question.
Yes, our Jaguar XJ 13-inch screen upgrade is designed to retain the factory cooling system operation. The OEM cooling fans and factory air ducting continue to work normally after installation, helping maintain proper airflow behind the screen and preventing overheating issues.
Our system is developed specifically for the Jaguar XJ platform and keeps the original vehicle functions working correctly. We are also aware that some low-quality aftermarket units on the market do not properly integrate with the factory hardware, which can indeed cause fan failure and overheating problems over time.
For our unit, the installation keeps the original system communication and cooling management functioning correctly, so you do not need to worry about the common overheating issue mentioned on the forums.
Some aftermarket units require transferring the OEM PCB/control boards from the original screen in order to keep the factory cooling fans, duct airflow, and certain vehicle communication functions operating correctly. Without this, some cheaper units can lose fan control and eventually overheat.
Our Jaguar XJ 13-inch unit was designed with this issue in mind. The system maintains the factory cooling operation correctly, so the OEM fans and airflow continue functioning as intended after installation. We have already considered the compatibility of the original hardware and vehicle communication during development.
