Restricted Performance
Old Yesterday | 04:23 PM
jaguar258's Avatar
Default Restricted Performance
Whenever i am on the Motorway, and i put a little pressure on the Engine, a Restricted Performance (RP) message comes up. Not all the time, but every now and then.
It is a 2.7 TVDI 56 plate and it runs very well, but when i can at times increase the revs then RP appears on the message area. I am wondering if that could be because of a faulty MAF Sensor.
Thanks for your help anyone.
Old Today | 10:04 AM
JagV8's Avatar
For non-UK, 56 means 2006
Old Today | 09:38 PM
RRpip's Avatar
Sounds like a classic overboost or sensor limit issue on the 2.7 TDV6.
MAF sensor is possible, but more likely a sticky turbo actuator, split intercooler hose, or the dreaded inlet manifold flap problem.
First thing: clean the MAF with electrical cleaner (cheap fix). If it comes back, get the fault codes read - RP usually logs a P0234 or P006A. Don’t just throw parts at it.
Check the small rubber hoses to the turbo solenoids too. They rot.
EscapedApe
Mar 10, 2026 10:24 AM
Jcbkwb
Sep 18, 2024 04:36 PM
scottatl
Feb 9, 2024 08:26 PM
sogood
Dec 20, 2023 10:53 AM
