Hi everyone,
I have leakage from cylinder #1 and #4 on my engine. The engine has almost 120K miles.
Both local mechanic and official dealership told me that all 4 injectors should be replaced due to mileage. And the price is huge higher than my car value.
After some research and Reddit post I decided to replace the two copper seals by myself, but I afraid to mess it up.
Here some YouTube video I have watched
https://youtu.be/d5vNLuEuX-I?si=_K8_jZwvZTFlUqen
The parts I found on jagbits.com
Here are my questions:
1) what materials/degreases should I use in order to clean the carbon buildup?
2) Should I use anything to loose the bolt? I afraid to break it during opening.
3) How should I clean the injector when there are out?
4) What is the torque value for the injector bolt?
5) In case I will discover broken injector, should I replace all 4? Does it require any calibration for the new injectors?
you need to pre-clean the openings in the valve cover where the injector and the injector clamp bolt passes deep inside.
your best bet is probably going to be a strong engine degreaser and a pressure washer to remove the debris, then use a compressor blow gun to finish cleaning out debris and leftover water from the pressure washer.
you cannot let the debris drop down in the threads of the bolt or on top of the pistons when the injector is removed.
there is a special injector wire brush used to clean the surface where the copper injector seal seats.
Yes, before removing the injector clamp bolt and the injector itself spray a Bolt Penetrating spraylubricant down in both holes to free up the bolt and lubricate for ease of removal.
you cannot clean them internally you can only clean off the carbon on the nozzle tips with a small brush and some carburetor cleaner.
you have to be very careful not to bump the tip of the injector, and not to scrape the very tip where the microscopic holes that inject the fuel are located. The injectors cannot be swapped to a different cylinder and must be reinstalled to the same cylinder. The return port, and fuel inlet Port should be capped to prevent debris from entering the injector. just a little debris can plug the nozzle.
it is not a torque value it's an angle degree (torque angle). you cannot reuse the injector bolts. they are one time use torque to yield or stretch bolts.
if you attempt to reuse them and use the angle in the specifications the bolt will most likely snap or loosen up over time.
it's not really possible for you to notice a broken injector visually. if when praying out the injector from the head the tip brakes off you are screwed, and most likely the head will have to come off to get the injector tip out of the port. The injector must be pulled straight upward. Don't allow it to tip side to side when pulling it out.
5) Does it require any calibration for the new injectors?
yes. each injector has a code on the body that is used to adjust the flow rate in the ECU when replacing with new injectors. if you run them on a test bench, clean them, and disassemble them for any type of repair they need to be re-coded on a Bosch fuel injector stand and re-programmed onto the car again. The injectors are JLR proprietary Bosch.
Note: I just went through this process recently and instead of replacing all of the injectors because I had a lower mileage, I took them to a fuel injection shop and had them flow tested, and pattern checked. they were all good and very equal flow. when they fail either some of the ports get plugged up and or the spray pattern is wrong, and or they over inject, under inject, or have too much leak back from the return port.
cautionary note: if your injectors have been leaking past the copper seal for a long time it can damage the head surface at the seal area. if this happens a special tool is needed to repair the surface before reinstalling the seals. basically compression blowing past the seal makes a little groove in the aluminum head. the compression will simply squeeze past and burn the new seal to the point of leaking again. also it is a good idea to anneal the copper seals before installing the injectors. When softening them up, they crushed and seal better the first time.
Cautionary note: the fuel injector metal lines are also one time use. They originally crushed and deform into the proper seating surface. The first time they are installed. If they haven't been reused before, and they're in good shape, you can reuse them and then just check for leaks to replace any line that does leak in the future. Do not torque them to the specification on the second time of use or you will damage the seal surface. The new torque spec is by hand (damn tight).
Your best bet is probably going to be a strong engine degreaser and a pressure washer to remove the debris, then use a compressor blow gun to finish cleaning out debris and leftover water from the pressure washer.
You cannot let the debris drop down in the threads of the bolt or on top of the pistons when the injector is removed.
There is a special injector wire brush used to clean the surface where the copper injector seal seats.
I got two bottles of Gunk engine degreaser spray and plan to use them to clean everything as much as I can. I’m a little worried about having to clean inside the bolt threads, so I’ll try to clean it as best as possible without going too deep into them.
yes, before removing the injector clamp bolt and the injector itself spray a bolt penetrating spraylubricant down in both holes to free up the bolt and lubricate for ease of removal.
got it, thanks!
You have to be very careful not to bump the tip of the injector, and not to scrape the very tip where the microscopic holes that inject the fuel are located. The injectors cannot be swapped to a different cylinder and must be reinstalled to the same cylinder. The return port, and fuel inlet port should be capped to prevent debris from entering the injector. Just a little debris can plug the nozzle.
Can I just use same engine degreaser and to clean it from outside?I found this really helpful video from a guy doing exactly the job I need to do:
I was wondering where I can buy those injector hole covers, or what people usually use as an alternative to seal all the openings while cleaning.
Also, do you have a link for a decent but not too expensive metal brush for this kind of cleaning?
The video is cut a little, so I couldn’t fully understand — did he use the same brush both for cleaning the injector itself and for cleaning inside the injector hole?
it is not a torque value it's an angle degree (torque angle). You cannot reuse the injector bolts. They are one time use torque to yield or stretch bolts.
If you attempt to reuse them and use the angle in the specifications the bolt will most likely snap or loosen up over time.
I got 4 new bolts, but what is the correct torque angle specification? In the previous video, did he torque them to 10 Nm first and then do 2 × 90° turns?
It's not really possible for you to notice a broken injector visually. If when praying out the injector from the head the tip brakes off you are screwed, and most likely the head will have to come off to get the injector tip out of the port. The injector must be pulled straight upward. Don't allow it to tip side to side when pulling it out.
Is there any special technique or tool for pulling the injector out straight?
Yes. Each injector has a code on the body that is used to adjust the flow rate in the ecu when replacing with new injectors. If you run them on a test bench, clean them, and disassemble them for any type of repair they need to be re-coded on a bosch fuel injector stand and re-programmed onto the car again. The injectors are jlr proprietary bosch.
I don't think anyone in my area has test bench, lets say worst case scenario I buy 4 new aftermarket injectors, theyprobably have some numbers on them so could i just update it to ECU, what tool shoul i use to interface with the ECU?
pretty much anything you need is available on Amazon.
The Port caps are very important to cap off the rail and the injectors them selves.
when you're cleaning the injectors you don't want anything to get inside ports.
i'm starting this reply thread and will add to it a little at a time as I have time.
i'm in the middle of a project right now and it will take me some time to come up with answers.
One thing I should mention is I have not had a reason to program injectors into the ECU on this particular vehicle. I have looked on my scan tool and I can see all the codes currently set in the ECU but I have not confirmed that my scan tool can actually update them.
The biggest issue with ScanTools is the information is very generic as to what the scan tool can actually do. once you purchase one you find out that a lot of options do not function on a particular year make or model, but work well on other vehicles. Jaguar in particular is very difficult to do much of anything without TOPIX on an OEM Scan tool. you can buy the set up from Mavericks that the dealer uses as a third-party but it's very expensive and you have to buy a subscription as well. I am using a Launch PAD V, with very good results but some functions are locked out by JLR.
By the way I had time to take a quick peek at the video and I wouldn't put too much weight in what he did. The torque angle he used is the incorrect torque angle. I'll post the correct one here as soon as I find my spec sheet. a pre-torque setting and then I believe 162°
i'll confirm later because what he did on the video damages the bolts and he's lucky he didn't strip or snap but they may loosen up later.
Engine degreaser will take the heavy oily greasy film off of the injectors and the upper cover of the engine, but will not do much for the carbon buildup. for that you'll need something more like Bermans B12 spray (carburetor cleaner) and a very small wire brush.
you can use the steel version on most of the body but not the tip. The brass version is a bit better at not scratching things up.
you can use a small prybar to pop the injectors straight up very carefully. they should come out fairly easily, if they are stuck there is a special tool basically a slide hammer handle that grabs the injector and pulls it straight up. if you had leakage they're probably in their very loose and will just lift out by hand. The bigger issue is all the crap stuck to everything falling into the pistons when the injector comes out. you need to do a lot of intense pre-cleaning. on my final cleaning or used a probe with a rubber tip to stick in the injector hole in the head while finish cleaning the holes so debris could not get into the Pistons, and then used compressed air to get everything out.
Reason: add to
