E type ( XK-E ) 1961 - 1975
Automotive engineering at its worst… High low beam switch.
Old May 22, 2026 | 11:44 AM
mpawelek's Avatar
Default Automotive engineering at its worst… High low beam switch.
I noticed when I bought my E-type that the far right rocker switch on the dash panel had no markings and was not electrically connected to anything. Looking it up in one of my books I found that this was the switch to change the headlights from high beam to low beam and back. Just what exactly were the engineers thinking? A switch that far to the right is such a hassle, reaching over there having to change the beams from high to low, etc. multiple times per trip was not very well thought out. I assume designed for the right hand side E Types. Now I know why someone installed another switch for this option on the left-hand side of the steering wheel. Much easier to get to while driving at night. Has anyone else found a handy use for this extra switch?
Old May 22, 2026 | 12:16 PM
Valerie Stabenow's Avatar
Default Your info is a bit off
The rocker switch at far right is for the electrically heated rear window, for cars that came equipped with that ( mine did). The gauge/instrument strip is also different between Es with and without the heated rear window. The high/low beam for the headlights is the toggle switch at left of steering wheel. your second photo.
Old May 22, 2026 | 01:41 PM
lrgridley's Avatar
That rocker switch is non functioning on all late roadsters. As Valerie mentions, It's for the headed rear window in the coupes.
Old May 22, 2026 | 02:17 PM
mpawelek's Avatar
I wonder why they installed a functional switch instead of a much cheaper blanking plate. Esthetics? There are four male attachments on the back though who knows if it is original to the car.
Old Jun 12, 2026 | 10:49 PM
mxfrank's Avatar
I guess it really much bother you. It's likely original. Jaguar probably found that mounting an extra switch was cheaper than tooling up for a different switch panel or a blanking plate. These switches likely cost next to nothing when new. Owners with the extra switch use it for things like disabling the ignition, activating an alarm, operating a power antenna, turning on an amplifier. Use your imagination and come up with a use or just forget it's there.
Old Jun 13, 2026 | 03:56 AM
mpawelek's Avatar
It does not bother me being there. I was just curious as to its use. Okie dokie?
Old Jun 13, 2026 | 10:31 AM
I don't think it's that this bothers him that's the matter.. He's a newcomer to the E world and just wants to understand how these cars are put together and how to best take care of them. We owe it to all our forum members, new and long-time, to be as helpful as possible.
Old Jun 13, 2026 | 01:43 PM
David84XJ6's Avatar
On my 1968 E , I hooked up radiator fan relay to that un-used switch... In southern California summer weather, stop and go traffic; I could turn on radiator electric fans before temp switch kicked them in.
Rgds
David
Woad29
Dec 29, 2023 08:32 PM
Sacho
Apr 11, 2020 02:20 PM
Domesticated NOT Declawed
Aug 13, 2017 11:11 PM
Don-T
Oct 6, 2013 10:48 AM
