Rear hub play between half shaft
Old May 24, 2026 | 11:12 AM
Robert Laughton's Avatar
Default Rear hub play between half shaft
Hi Folks,
When I shake the wheel while holding at 6:00 and 12:00, there's too much play, between the half shaft and hub.
At first I thought a thicker spacer may be needed, to take up about 20 thou.
But then I thought the spacer really doesn't see wear, maybe it's the bearing.
I do see wear on the ABS ring where the bearing rides, and I do see slight wear on the spacer.
Which part do you thin is more likely to need replacement. I'm thinking if the bearing were new, the spacer would be correct.
Thanks,
Rob
Old May 24, 2026 | 02:56 PM
xjack's Avatar
Things to check apart of hub bearings, are pivot bearings, differential output shaft and universal joints, i don't think wear you see makes any difference, probably hub bearings are gone and slight slack caused some scratches
Was the hub nut tight when you were taking it apart?
Old Yesterday | 12:39 PM
Vauxi's Avatar
Half shaft U joint play can easily felt as bearing slack.
night_row
Jun 20, 2025 05:54 PM
Asdrewq
Mar 29, 2024 01:41 PM
Greg in France
Feb 20, 2024 12:58 AM
Rarity87
Nov 16, 2020 07:17 AM
bhmaxjag
Mar 16, 2009 10:32 AM
