Unknown Connector
Old Today | 07:16 AM
euphonium01's Avatar
Default Unknown Connector
Hi all. I have had the dash removed doing various items with the heating and blowers groaning with bad bearings. I've put it all back together, but there's a small, two pin, connector that comes driectly off the ignition switch (where the key actually goes in) and I can't find anywhere it should connect to. The two wires to it are White and a Brown, the connector itself is white. The wires have are both covered in what looks similar to shrink wrap tubing. Mine is the 3.2 Sport model so not sure if it's something for a higher model car and left unconnected for mine?
Anyone any ideas please?
Paul
Old Today | 07:31 AM
Peter_of_Australia's Avatar
If I may hazard a guess: My very first guess was that it is the connector the transponder receiver ring, hence I asked my AI program:
"Jaguar X308, 1998: What does the connector going to the transponder-receiver around the ignition lock look like?"
And the answer was:On the 1998 Jaguar XJ8 (X308), the immobilizer transponder receiver is the black plastic ring (antenna coil) around the ignition barrel. The connector going to it is usually:
  • a small 2-pin connector
  • black or dark grey plastic
  • with two thin wires leading into the steering column harness
  • mounted very close to the ignition switch housing
The receiver itself is only an antenna coil, so it normally uses just two wires.
Typical wire colors on many X308s are:
  • white/slate (or white/grey)
  • black/light green
    …but Jaguar wiring colors can vary by market and year.
Visually, it looks something like this:
https://images.openai.com/static-rsc-4/gvQBrvISzJ9kOKfHHM3Gi2e53o0i59ym8K-zkKpkUzI72LdZs-EePYXyGcZCscKAlxvZmiduv1UaGG5n8LZtcxalY0TjLJskveb8  QAhM3TgH7d8rktQiNUv0OS_KeuQCfnShtJB7xm44LlFR2XVIMf  U1n4r7n2V9UiSl2qClwoFowpiF_Rrv2hjBvmKEC8Rf?purpose  =fullsize
https://images.openai.com/static-rsc-4/dUfp84v6NtDCqLgJ435JHwphzIzAkCYSEcHetQKAYy6yQePyxv  3OIBgRrGJhFPGCQRg6gXeVjWuiZaEnhz1nTUebOo83ARwVpvey  L9yf7bZLQJksuv55zGHGzut7i3RLAxEqAg_APh1Dw5XFKYwZ-pQlQYIwseqigRzHGS-6yJ3aBfz5ewIBT1u9MKJKZszo?purpose=fullsize
https://images.openai.com/static-rsc-4/UNhqmhXrQ696pZEEcdyIRipEzeIf7zyo1pzd3tFuYeZ5pBHFZZ  WNFH6CWU9_9OemjKuJkF16HJhoFjbJU2iQlGgQBqI0p_hhbFws  oUkXdBGh_K259VV4-bf8Z9JXs3icrn7w6bxB_c0_tfceGeI9gQoZ7ZPb3MNGnEsJEuF  Gy5kN0DOAxMnne2kLjPEmAYrk?purpose=fullsizeThe connector is located:
  1. Behind the steering column shroud
  2. Directly around the ignition lock cylinder
  3. Usually clipped onto the immobilizer ring assembly
If you remove the upper and lower steering-column covers, you should see:
  • the circular antenna ring around the key barrel
  • a short pigtail cable
  • the small 2-pin plug connecting into the column loom
Old Today | 07:54 AM
Hi Peter_of_Australia. The one in the Autoworks Motors picture is it!!... that's the one
As the cable is so short (as you observed) I need to find the Transponder Receiver now and a cable from the Transponder that connects to the Key Lock connector you idntified for me.
Thank you so much, I will let you know soon as...
Paul
Chip Abbadessa
Feb 21, 2023 08:04 PM
4zfed
Dec 9, 2021 02:56 PM
avern1
Sep 23, 2015 03:25 PM
macster2751
XJ40 ( XJ81 )
Dec 16, 2013 10:53 PM
Dave S
Aug 1, 2010 01:43 PM
